Ok, I was not comparing like with like ('cos you can't)but the 10 speed 11-36 XTR cassette on my bike is around 235g if memory serves. Am sticking with this because I have enough gears with a 30T chainring. If someone did an 11-40 10 speed that was similar in price and weight to what I have I'd get it right away.
Praxis at 320g is lightest xtr is 270 according to Google, so it's only 50g
Thatextra 40t sprocket doesn't come for free, personally I think it's well worth it for the extra range (an e tra 50g going from my xt to my mx3)
The only thing I can't speak too is longevity as I've not had mine long
After two rides, I'm extremely happy with my setup. Getting everything adjusted took a little longer than usual, the setup is quite sensitive to adjustment. Once fettled I couldn't tell the difference in shift quality between old and new.
I do plan to swap my 36T front chainring for a 32T somewhere down the line and to ditch the front mech entirely but I'm in no great hurry considering that a new XT chainring costs around £50. I can live with the extra weight of a front shifter, front mech and cables, given that a winter ride round my way will deposit over a pound of mud on my frame.
Two rides in, 40 miles and some decent climbing. Spot on, cant fault it at all. Found it no difficult to set up than my usual 10 speed setup.
I've been running one on my fatbike since November. 2-3 rides a week through the worst sandy muddy slop or actually on the beach.
The black finish has mostly gone, but still shifts perfectly (X7 mech so designed for 1-by) and shows little sign of wear. Think I'll be going this route on all my bikes as the range of gears is fine for my purposes.
Stuck my MX3 on but not adjusted B Screw yet.
40T at the back with 30T NW up front with SLX clutch mech - not sure off hand if its med or long cage. Is adjusting the screw a piece of piss or more involved than it should be?
Piece of piss really. You can't miss the screw, just wind it all the way in.
Went out on bike with Sunrace cassette on last weekend...when climbing using the 40T it was jumping all over the place - the one gear I pretty much bought the cassette for! Pretty sure the B screw is right in...any other reason why this might happen?
My 42 sunracee was running fine through the filth at valelujah this weekend, and I was using the 42 a lot on those long climbs. I have got a rad cage on tho.
Limit screws right?
