Sucking 456
[Closed] Sucking 456
[#2652406]
What bits should I replace to help sort the chainsuck on my 456? Running XT 3x9 on a 20"
Even does it a bit in the dry. . .
Posted : 11/04/2011 10:13 pm
throw the large chainring in the bin, and shorten the chain so it runs tighter = less chainsuck.
Posted : 11/04/2011 10:22 pm
Yes, I've been getting round it by just using the big ring to keep the chain tight.
Was hoping someone might say buy a different frame 🙂
Posted : 11/04/2011 10:45 pm
Replace the chain rings with cheaper deore steel ones. Every time I've used expensive light ali chain rings I've experienced some chain suck. I'm convinced the chain picks up on the softer Ali rings. Never had a problem with steel ones! I'm running 3x9 on a 456 with deore crank and rings with a Sram chain.
Posted : 11/04/2011 10:50 pm
I heard a tip (second hand) about chainsuck, the theory being that it's the burrs that collect on the rings that cause it, if you go round the ring edges with a knife and trim them off, hey presto no chainsuck - should point out that I've not tried this yet as my chainrings are steel and still fresh...
Posted : 12/04/2011 12:05 am
Aye, I've milked a fair bit of extra life out of old chainrings by going at them with a round file... But it's just postponing the inevitable really, which is new rings and chain.
Posted : 12/04/2011 1:09 am
I wish someone would bring back the onza buzzsaw stainless middle rings.
Posted : 12/04/2011 7:55 am
Deore steel rings, consistently clean + lubed chain (Rock N Roll is good), and a double+bash with a shorter chain and short cage mech
Posted : 12/04/2011 8:26 am
Yeah, take the rings off and check for burrs. File them off and you should be fine. It's something I do regularly on my bikes and certainly before a big ride away from home.
Posted : 12/04/2011 8:30 am
Ring filing sounds like a nice little evening job.
Posted : 12/04/2011 10:23 am
Clean the chainrings up and file. If too far gone, a new chainset will do. In which case, how about a new frame to hang it on? 😉
Posted : 12/04/2011 10:34 am
Sounds like the advice my wife was after 😉
Posted : 12/04/2011 11:05 am
13 posts and no-one has said the frame!!
Posted : 12/04/2011 11:19 am
singlespeed = no chainsuck
Posted : 12/04/2011 11:27 am
Have just filed my middle ring and will be testing this out tonight, have also rotated it 90 degrees to even out the wear a bit.
Also made sure the teeth aren't gonna snag the chain by rounding of the tip of the teeth slightly.
Considering running a deore steelie in future.
Posted : 12/04/2011 11:33 am
Belt drive?
Posted : 12/04/2011 11:36 am
Nope, all my filing hasn't made much difference, bugger new drivetrain time.....
Posted : 13/04/2011 11:08 am
 Tim
I struggled to find a setup that worked on my 456 with a deore octalink setup that had worked perfectly on previous bikes
chucked on a new slx triple - solved problem
Posted : 13/04/2011 12:23 pm
Ummm, bigyinn. Am I being daft, won't rotating the middle ring by 90 degrees mean that the shifting ramps and lower teeth which help shifting are misaligned, possibly exacerbating chainsuck?
Apologies if I'm being stupid...
Posted : 13/04/2011 1:15 pm
