OK, so maybe it's just because I've been spoilt by all the years of LockOns, but those stock Brompton grips are a bit gash, aren't they?
So, what's the skinny on grips? (M type bars, BTW)
Can you get something like an Ergon to fit? Might be a nice comfy set up for that type of riding.
TIA.
Yeah, the foam ones are a bit naff - and they're glued on so you need to cut them off and get scraping.
Ergons fit, but you need to cut them down a bit because the M-type bars are quite narrow.
Ta. Will investigate further.
One other option that I thought might work would be using a Gripshift version of a LockOn grip, as that would be a little shorter. Anyone tried that?
I've got ESI chunky on mine, mainly as a result of using them on my mtb. I think they're brilliant grips and don't shift around at all. Not a brompton but a folder of the cheaper variety.
The diameter is right - might be a little too short, but I've not tried.
