I've lost the latest issue of STW which annoyingly contained the map of the Peak route around Edale, Hayfield etc. 👿
Is it similar to this one? http://www.bikemaps.co.uk/peak_district_edale.htm
Would be cheaper to buy this than the mag again (which I read cover to cover!).
That's the one, but you probably won't need the map once you've studied it, it's pretty simple. Really good Dark Peak taster, good mix of everything. If you're doing it midweek, the bit over Rushup Edge would be better on the footpath, it's rock rather than mud and will be more fun to ride.
Cheers thought it was similar - wont need to ask for a scan then lol 😀
Nickswolves, I have a PDF somewhere of the route I will find it and email it over to you.
Great route and a great day in the saddle.
Thanks tommid that would be great - I've emailed your address on your profile. Cheers
It's also know as Kinder Circuit, great ride!
