stupid question for...
[Closed] stupid question for the day - 1/8 vs 3/32 chains...
[#1584653]
I have no idea with these old school imperial numbers... Basically I have a 32T on-one SS chainring, what chain is this meant for?
To confuse the issue, I also have a 36T Velosolo chainring that has much thicker/bigger teeth than the on-one, I've already discovered that my normal chain doesn't go over the teeth, so what size is it? 1/8 I think?
I'd like to be able to try both chainrings in my SS setup, to see which ratio I prefer, so what size chain should I get?
help a confused modern man please 🙂
Posted : 07/05/2010 3:59 pm
anyone? want to place an order with CRC 🙂
Posted : 07/05/2010 4:15 pm
I'm pretty sure you need 1/8th with the on-one chainring - it's quite thick.
you can use 1/8th with a 9 speed chainring/cog anyway.
Posted : 07/05/2010 4:18 pm
so 1/8 is the thicker one?
Posted : 07/05/2010 4:20 pm
1/8th = 4/32nds, so yes.
Posted : 07/05/2010 4:21 pm
 jonb
1/8 = 4/32 so bigger than 3/32 the 1/8" is thicker and will fit anything. the 3/32 may not fit.
Posted : 07/05/2010 4:22 pm
3/32" works fine on the on one ring.
edit: just *read* the post (makes a change for this place!!), you need an 1/8th chain for the other ring.
Posted : 07/05/2010 4:24 pm
cheers guys... I'm really tired and not thinking clearly this afternoon 🙄
