*STUPID QUESTION* C...
[Closed] *STUPID QUESTION* Can You Convert a 9m QR Rear to a 15mm Bolt Through???
[#3673699]
This is potentially a REALLY stupid question, but I'm just wondering if you can covert a 9mm QR rear axle to a 15mm bolt through?
Can you buy any sort of adapters etc?
I know you need to change the hubs etc, but would it fit the actual frame?
Sorry for such a newb question!
Posted : 13/02/2012 6:54 pm
Some hubs (Hope Pro2 etc) allow conversion.
But you can't change the frame unless you've got bolt-on dropouts of some sort.
But a frame with qr 10mm dropouts (forks are 9mm, frames are 10) will allow a 10mm bolt-thru, like Superstar make.
Posted : 13/02/2012 6:56 pm
The bike in question is a 2011 Mondraker Foxy RR running a Crank Bros Cobalt wheelset.
Posted : 13/02/2012 6:59 pm
Why? I thought Mondrakers were quite stiff.
Posted : 13/02/2012 7:17 pm
I would say no to changing any rear type wheel to a 15mm I'm not even sure I've ever seen rear stays with 15mm configuration as ir said some wheels you can change out to fit 10 mm in standard 135 q/r rear drop outs but unsure regards crank bros wheels.
Bats
Posted : 13/02/2012 7:31 pm
The rear on mine flexes quite a bit. I'm a powerlifter (so pretty strong), and I ride quite aggressively.... Just want to tighten the rear up a little.
Posted : 13/02/2012 7:32 pm
I meant 12mm bolt through! Sorry.
Posted : 13/02/2012 7:34 pm
On some hubs, yes you can convert (Hope do).
I run a 135mm x 12mm axle on a Pro 2 - but use the Azonic Momentum axle to fit the 10mm dropouts.
http://www.chainreactioncycles.com/Models.aspx?ModelID=20271
Unsure on the wheelset you have though.
Posted : 13/02/2012 7:38 pm
I'd imagine they're standard drop outs so the best you'll be able to do is a 10mm bolt in or through. May mean a change of wheel though.
Posted : 13/02/2012 7:51 pm
 jedi
you can if you have 2012 mavic crossmax's.........oh i did just that ~:)
Posted : 13/02/2012 8:48 pm
To expand my answer,here the new dropouts I had made for my belt-drive Kona A:
[url= http://farm7.staticflickr.com/6196/6050686768_a44cebd559_b.jp g" target="_blank">http://farm7.staticflickr.com/6196/6050686768_a44cebd559_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/6050686768/ ]DSC_0518[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Designed for 10mm bolt-in hub (Hope Pro2 Trials)
[url= http://farm7.staticflickr.com/6202/6121970692_a2399cdb2f_b.jp g" target="_blank">http://farm7.staticflickr.com/6202/6121970692_a2399cdb2f_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/6121970692/ ]DSC_0008[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
And yes, it stiffened the rear end up.
Posted : 13/02/2012 9:54 pm
Coaster brake on the back?? 😆
Posted : 13/02/2012 11:03 pm
Foxy dropouts will not convert but you can change some wheels to a 10mm bolt through qr.
i have done this on my dune and its a big improvement
email me if u want more info. on phone now
Posted : 13/02/2012 11:44 pm
