Do cantis and V's use the same stud position studs?
Ta
Andy
Posted : 29/09/2012 12:07 pm
Yes - only U-brakes were different.
Posted : 29/09/2012 12:22 pm
Thanks for that. As a follow on, if I was to fit V's, what's the recommendation for which ones to go for?
Andy
Posted : 29/09/2012 6:46 pm
But you should know that ideally you need to change the levers as V brakes need lever that pulls more cable..
Posted : 29/09/2012 8:39 pm
Yes; if I change the brakes, I'd planned to do the levers as well (as this is the Hybrid of Doom, the cantis are cheap no-name ones*, as are the existing levers).
Andy
*or at least the back one, which is sticking, is.
Posted : 29/09/2012 9:28 pm
