Since the DOT fluid label tells you your arms will fall off and the entire eco system will perish if they touch the fluid - how do you 1) dispose of the used fluid and 2) clean your bleed kit out having bled the brakes?
Posted : 17/04/2011 7:17 pm
Dipose of it in your local recycling centre in the oil disposal point IIRC, just empty the bleed kit and leave it
Posted : 17/04/2011 7:19 pm
What he said^^.
There's no need to clean a bleed kit out, just tip the dregs out of the pump.
Garages that deal with larger quantities of used brake fluid just tip it in with the waste oil.
Posted : 17/04/2011 7:25 pm
Cheers!
Posted : 17/04/2011 7:30 pm
