Stunt Jumper DU bus...
[Closed] Stunt Jumper DU bushing help
[#4229960]
Do I need to replace this bushing on my 2006/7 s works. It has the specialized asr shock and brain.
The bolt keeps coming loose after my lbs checked the bushing and tightened it up.
If over tightened it creaked when the shock is extending. Final straw was whilst at Afan yesterday the bolt nearly came out, should the bike shop of used locktite?
Are there any alternatives to this bushing these days?
Posted : 06/08/2012 8:05 am
BETD do a replacement but its still a similar setup...
Unsure why it should come loose though, normally they just knock a bit but no safety issue.
Posted : 06/08/2012 8:10 am
Thank you, I was shocked, shouldnt it need locktite?
Posted : 06/08/2012 10:51 am
