Stumpjumper S works...
[Closed] Stumpjumper S works headset???
[#2886500]
I recently bought the above frame without the H/S. Does anyone know what replacement aftermarket H/S will do without having to purchase from Specialized.
I've done some digging and cane creeks name came up, but I don't know if this is the exact H/S I need. Think it was a IS 2 that was mentioned???? Details below..
Replaceable sealed catridge bearings with neoprene bearing seals steel crown race with integrated rubber seal
Features:
• Replaceable sealed cartridge bearings with neoprene bearing seals
• Upper stack Height 8.3mm(1inch)/15.5mm(1-1/8 inch)
• Lower stack Height 0.4mm(1 and 1-1/8 inch)
• Total Stack Height 8.7mm(1 inch)/15.9mm(1-1/8 inch)
• Weight 71g(1 inch)/88g(1-1/8 inch)
Bearings 36x45 degree[b]
The above doen't mean a lot to me, but would be grateful for your advice if it does.
Thanks
Posted : 25/06/2011 3:39 pm
Check what it came with originally in the Specialized archive
http://www.specialized.com/gb/gb/bc/home.jsp
Posted : 25/06/2011 4:23 pm
