Stumpjumper integra...
[Closed] Stumpjumper integrated headset small gap?
[#7851208]
Anyone please post up a close up of your headset?
I've just replaced the bearings and have a small 1-2mm gap between the top cap and top of the frame. I don't remember having one before and pretty certain I've put it back together ok (integrated so only 2 bearings, compression ring and top cap involved).
Posted : 25/05/2016 8:57 pm
Where did you get your bearings?
Posted : 25/05/2016 9:13 pm
annoyingly not all bearings are created the same so even if think you have the correct dimensions eg 45x45 they can still vary a lot.
It's really annoying, we have this problem at work a lot and we've started to keep bearings from different suppliers to try and combat this.
Posted : 25/05/2016 9:27 pm
Got them from MB bearings online, they certainly look exactly like the ones they're replacing
Posted : 25/05/2016 9:58 pm
Hi Yoshimi,
Here is a pic with and without the top on my 2016 Stumpy frame.
[URL= http://i442.photobucket.com/albums/qq141/john190784/Mobile%20Uploads/DSC_0493.jp g" target="_blank">http://i442.photobucket.com/albums/qq141/john190784/Mobile%20Uploads/DSC_0493.jp g"/> [/IMG][/URL]
[URL= http://i442.photobucket.com/albums/qq141/john190784/Mobile%20Uploads/DSC_0494.jp g" target="_blank">http://i442.photobucket.com/albums/qq141/john190784/Mobile%20Uploads/DSC_0494.jp g"/> [/IMG][/URL]
Posted : 25/05/2016 10:33 pm
Make sure they are the exact same bearings. Specialised use Campy style bearings which are much flatter on the bottom and not quite so deep. Hopefully that makes sense.
Posted : 25/05/2016 10:45 pm
Probably the bearings then, we use a bearing supplier for big boxes of headset bearing in 99% of sizes bit none of them 100% match the specialized ones. Almost impossible to notice a difference until you fit it.
Posted : 25/05/2016 10:47 pm
Thanks guys, maybe I'm not doing it wrong after all - I'll try putting the old bearings in tonight and see how that fits.
Posted : 26/05/2016 8:13 am
Normal!
Got the same style headsets on my Camber and Epic and both have a gap - even with stock headset or replacement cane-creek one.
Almost looks like the bearing seat at top of head tube could be machined deeper, but haven't had any issues over past 3 years with the gap....
A
Posted : 26/05/2016 8:19 am
THIS^^^^^
It's so shallow.
I was wondering if I'd dropped a rubber o-ring or something - sealings not exactly great on these things is it
Posted : 26/05/2016 8:25 am
[url= https://www.evanscycles.com/specialized-stumpjumper-fsr-expert-carbon-evo-29-2014-mountain-bike-EV193955 ]stmpjumper pic[/url]
Zooming in on this also shows a gap
Posted : 26/05/2016 8:56 am
It's a Specialized thing. My new Hope headset cap wouldn't fit my Stumpy frame because of this.
I can't see why they didn't machine an extra 2-3mm of depth into the bearing seat either.
Posted : 26/05/2016 9:52 am
Yip mines the same 2016 29er stumpy has the gap never had a problem
Posted : 27/05/2016 10:58 am
Thanks for the replies, makes me feel much better:)
Posted : 27/05/2016 2:55 pm
PJM1974 - Member
Hope now make two different types of IS41 headset - the Type 3 and the Type 7 (campy style)
The #7 has a deeper cap, I had a gap on my Last with the type 3, type 7 is perfect.
Posted : 27/05/2016 4:05 pm
Specialized do say it's Campy style
Posted : 27/05/2016 4:47 pm
FYI - must have been the bearings - took the seals off the old ones (they weren't too bad really), cleaned them out, repacked with grease and put back together - no gap! Prob leads me to buy official bearings next time or the Enduro Max ones
Posted : 03/06/2016 9:53 am
