Stuck seatpost - an...
[Closed] Stuck seatpost - any tips?
 wl
[#7920685]
Anticipating problems getting my reverb out my ali Five frame after 6 months of not using it. Any tips? Ta v much.
Posted : 01/07/2016 3:27 pm
As always Sheldon has the answer -
http://sheldonbrown.com/stuck-seatposts.html
If these fail then there is the seatpost man.
Posted : 01/07/2016 3:34 pm
 wl
Wow - cheers Stevet1 - pretty comprehensive! Thick question but I'm assuming my Reverb is aluminium?
Posted : 01/07/2016 3:41 pm
Yes, go easy trying to twist it out, you may well bugger it if you overdo it!
Posted : 01/07/2016 3:48 pm
I'm having the same problem with mine. Tried all sorts apart from cutting it out. Alu post in a steel frame so I'm going to give it the caustic soda treatment. Obviously not an option for your alu frame.
Posted : 01/07/2016 3:52 pm
Is there a hole at the bottom of the seat tube, so you can turn bike upside down and pour a can a cola flavoured drink into the tube? Then ~24 hours later use wood and mallet to hit saddle to loosen the post.
Did this over 25 years ago to free a post on my old Peugeot 531 racer, worked a treat! 😀
Posted : 01/07/2016 4:46 pm
+1 for cocacola
Posted : 01/07/2016 4:48 pm
Argos racing cycles in Brizzle and £45
Posted : 01/07/2016 4:59 pm
Not sure a can of Coke and a Reverb will mix 😮
Posted : 01/07/2016 5:07 pm
