Stuck BB in carbon ...
[Closed] Stuck BB in carbon frame
[#6412874]
Trying not to panic here but my Hive / e-thirteen BB (threaded) is completely stuck in my Santa Cruz TRc frame.
I know what direction to turn and have tried to soak it in WD 40 / thin oil.
I´m afraid that if I put too much force on it, with long lever etc, the inner threaded steel insert will disbond from frame.
Please give me your best advise!
Thanks
Posted : 14/08/2014 8:29 am
There are various tricks including cutting them out, but perhaps a job for a good shop - if you're anywhere near Glasgow I can have a go.
Posted : 14/08/2014 8:40 am
A good bench vice/bb tool inserted and use the whole bike as a lever(very gently) has done every bb I thought would never come out 🙂
Posted : 14/08/2014 8:43 am
bencooper; thanks, but me and the bike are in Sweden..
Plus one; I´ve heard about this "bike lever" method and just wonder if it OK with carbon frames??
Posted : 14/08/2014 8:48 am
Ah, a bit far 😉
The bike lever technique is a good one. Get a good BB tool, and clamp it in using the crank bolt.
And, just to be sure which way you're turning: with bottom brackets right is left and left is right...
Posted : 14/08/2014 8:50 am
Problem solved.
Mixed WD 40 and thin oil and soaked the whole BB area over night.
Fixated the BB tool from e-thirteen with a long QR so it couldn´t come off when I put the lever /crank to it. Extended the crank with a 90cm long lever and off they came!
All´s well that ends well. Thanks for support!
Posted : 14/08/2014 9:05 pm
