Stripping a 7005 al...
[Closed] Stripping a 7005 aluminium frame back to raw?
[#2158902]
What's the best way? Can I get a professional to do it (guessing sandblasting wouldn't be a good idea)?
Posted : 04/11/2010 10:34 pm
Painted?
Why not bead blast?
Why do it anyway?
How's the diet?
Posted : 04/11/2010 10:37 pm
as above whats the current finish on it?
I'd go for either a bead blast or a chemical dip.
Nitromors works just fine
Posted : 04/11/2010 10:39 pm
How's the diet?
88kg today 8) Have tailed it off a bit now, just continuing to build fitness and letting the weight loss take care of itself (two gym sessions today, 25km ride, 3km jog, 1.5km swim then in the afternoon it was a 1hr spin class and 1km in the pool 🙂 ) Aim is to get below 80kg now! 😯
Yep, the frame is painted, it's the Szazbo I picked up a while ago. It's been sprayed a horrible pinkish colour over the orginal blue, really needs to be stripped and repainted.
Posted : 04/11/2010 10:40 pm
take it to armour tech in hackney, £70 gets you a blast and powder coat in colour of your choice.
Posted : 04/11/2010 10:54 pm
have used them before, they're good from what I hear. Just worried that blasting wouldn't be good on a thin walled alu frame?
Posted : 04/11/2010 10:57 pm
Leave it to pros don't dream of getting involved.
should be fine as long as the correct blast media is used.
Posted : 04/11/2010 10:59 pm
[i]Nitromors works just fine [/i]
+1
it's an evenings elbow grease for a boggo hardtail
Posted : 04/11/2010 11:01 pm
If it's a lightweight aluminium frame be aware that powdercoat is heavy! It added over 1/4lb to a frame I had done compared with the wet-spray paint before.
Posted : 04/11/2010 11:03 pm
will probably get it properly painted, maybe by Argos or similar... I thought powdercoating was a no no for alu frames due to the heat or something?
Posted : 04/11/2010 11:04 pm
Correct toys19 is your man for advice on that.
Posted : 04/11/2010 11:06 pm
if you want it painting, drop me an email (as i'm a painter by trade)
Posted : 04/11/2010 11:17 pm
[url= http://www.armourtexltd.co.uk/pricelist.pdf ]http://www.armourtexltd.co.uk/pricelist.pdf[/url]
alu is dipped & blasted according to their brochure.
Posted : 04/11/2010 11:22 pm
