There may be a totally obvious answer to this question but I cant see It. I like doing little time trial routes to measure against previous times to see If I'm Improving but for some reason two of my local routes seem to double the distance (check the average speed) for loops. These routes are ridden in TTT's If that makes any distance.
Check the [url= http://app.strava.com/segments/2434089 ]link[/url] to see what I mean .
It is to do with the start and finish of a segment, strava seems to have issues when both points are next to each other as part of a loop. Iif you move the end point back a hundred metres or so it should sort it
Strava will let you register a time on an out and back route like that if you only ride 75% of the segment too 🙂
