Created a segment, but accidently saved it before I named it. Is there anyway to edit it so I can name it?
Hover your cursor over the title and you'll get the option to edit the title.
Go to the segment page. 'Actions' > 'Edit'.
You don't get the option to edit the title that way, just the length of the segment.
Delete it and start again?
[i]Delete it and start again? [/i]
this. I found I couldn't change the name of a segment.
Nah.. what AndrewJ says is right. If your the author, you can rename it as many times as you like. Hover over the segment title on the segment page, then click and the 'edit title' box will appear.
eh? I have been able to change name of a segment - as above, hover over, Edit Title, sorted.. even segments that have data from other users against them..
Aha! If you don't put a title in, it doesn't come up with an edit option as you don't know where to hover! Sorted now, cheers!
