My Giant TCR has a teardrop profile seatpost and I want a **small** rear light I can mount/remove quickly, so I think the rubber strap designs may work best. But, I guess, I want one which interfaces with a sharp trailing edge of the seatpost.
Any ideas?
I've got knog plus lights on my propel and planet X stealth. Both with year drop posts.
Another thing to consider would be under seat mounted lights.
Yellow foam off some local scaffolding, a knife and a normal seat tube/rubber band mount.
Works fine.
( I did it for a mate )
Failing that I’m sure exposure do a teardrop mount, might have to buy an exposure rear light though.
The see sense lights come with a clever aero seatpost mount. Easy to mount/remove as well.
If you're a BC member you get a good discount (maybe 20%?)
Hmm, good idea. Any reason why scaffolding foam? Is it particularly dense or something?
Garmin varia. They have an aero mount fitting
Pretty sure my Exposure TraceR has a sort of hinge arrangement on the bracket that would allow it to work. If nobody else gives you an answer by tomorrow drop me a message then and I'll have a look for you.
Edit: oh, well they do an aero bracket for it as well anyways! https://exposurelights.com/products/bike/brackets-and-mounts/aero-seat-post-bracket
Exposure does one for my Tracer but I'm too tight to buy it and had some Sugru sitting around and molded that to the bracket and Seatpost. Did have the foresight to wrap some cling film around the post first.
Slightly more old school than a TCR but this Cateye fits my 80s Campag Athena aero post (mine’s a few versions older, doesn’t have the motion sense).
https://www.cateye.com/intl/products/safety_lights/TL-LD710K/
I 3D printed a fitting for one of my lights to go from regular round to teardrop shape, but that's not necessarily a solution for everyone!
In true STW fashion....I have this. It’s been a great light.
Moon Cerberus
The moon lights come with a special hinged bracket that allow it to fit on aero seat posts.
I have a lezyne something or other.
It’s actually designed for aero seatposts.
It was about £30 and has many modes including ‘daybright’ if that matters to you.
I’m reasonably sure the exposure rear lights use a similar arrangement to facilitate ease of use with aero posts.
I've just bought his & hers MagicShine SeeMee 200's. These come with a rubber strap that will go around most seatposts. Also included is a mount for the saddle rails that can be left in position. The light itself is on a bayonet mount. Astonishingly bright, has a downlighter that illuminates the back of the bike in low light & a brake light function which I've switched off on ours. about 10 different modes to suit conditions.
One downside is that if you ride in a group others will get annoyed by its brightness.
For 40 quid I'm well chuffed.
Giant [EDIT] used to make one for you 🙂
https://www.rutlandcycling.com/accessories/lights/giant-numen-plus-aero-tl-rear-light_155805
I have one and it's fine. I also use either a saddle rail mounted Cateye light or a seatstay mounted Cateye Rapid X. I always ride with two rear lights.
And Always a Cateye mounting solution - adapter for aero posts
https://www.cateye.com/intl/products/parts/5447040/
Add to a Rapid and you are good to go.
I've got one of these on my Giant TCR seatpost shaped like yours:
Cateye SP-11 Flex Tight Bracket
It works a treat.
It's a fit and forget rather than easy to remove style but the wedge shape of the bracket works very well with the trailing edge of the seatpost.
what about one of the saddle mounted lights? i bought one of the cube lite II things, there’s a recent thread on the Xite 100 round version. £18 on amazon.
