Can anyone recommend any outside secure storage solutions? Something to keep 3 bikes, a bit of garden stuff and some fishing gear in? Probably with a maximum footprint of 8ft by 8ft. Its not something that I would be willing (or able) to build myself, so something off the shelf.
Regards
Pete
Take a look at Asgard sheds
Any specific one's? or are they much the same security wise? I cant seem to see the difference between the ones described as bike or motorcycle sheds and the normal ones, except a hike in price.
The bike specific ones get good reviews, I presume more secure. I don't own one, just been eyeing them up for sometime...
Try this Asgard shed...
http://www.asgardsss.co.uk/bike-cycle-storage/cycle-storage-maintenance
Delivery leadtime is about 4 weeks, and you'll need a decent based to put the shed on. I ended up using concrete.
Needs two persons to assemble, but easily done in 1/2 day. You'll need a decent electric screw driver, using a normal screw driver will take you all day.
I looked at other sheds but nothing else is as good unless on the market. Don't bother with B&Q or Homebase.
Shed does not come with shelving or hooks, these are at extra cost.
I wouldn't put owt in a shed bar paint tins and a few inexpensive garden tools etc
If I really had to I would line it with steel concrete reinforcement stuff welded together and a door with loads of security
Plus a concreted block with ring in the floor to lock stuff too but all this would probably be cost prohibitive
mattzzzzz i think what your discribing is called a garage 😀
