Stocking up on gear...
[Closed] Stocking up on gear cables/outers etc
[#10331821]
Does anyone have any particularly good recommendations for where to stock up on these on the cheap?
I used my last gear cable and bit of outer on Friday. Maybe outer on the roll and then a good few gear cables, the slightly longer ones if possible, I find my cable routing combined with a XL frame means the extra length is useful
Also need the ends and things (whatever they're called!)
(Gear cables, not brake cables!)
Posted : 15/11/2018 3:47 pm
Also keen on a roll of decent outer. Used to be able to find 10m of SP41 for £15. Cheapest I can find is £30
Posted : 15/11/2018 4:11 pm
Just boughtening "Bike GEAR Outer Cable casing housing 4mm (10 Meters) Fibrax Black" from ebay for under a tenner posted.
cyclefanatic on ebay*.
Edit: Getting some cables too. £6.39 for 10 galvanised . or £20 for 10 "premium slick" ones
Edit again: And £5 off orders of £35 or more. so I got 30m of outer for £25 and the £20 Fancy Dan cables. £40 posted for the lot.
*  turns out to be Fibrax themselves, according to he paypal receipt
Posted : 15/11/2018 4:19 pm
Are we stocking up in advance of Brexit?
Posted : 15/11/2018 4:27 pm
Also need the ends and things (whatever they’re called!)
Ferrules, but I stopped using them ages ago - just stick a blob of superglue on the end of the cable. It's neater and you can re-use the cable with having to chop the end off.
Posted : 15/11/2018 5:00 pm
Ferrules are for the ends of the outer. Cable ends or crimps are for the cables themselves. I use Fire Wire cable ends, which are reusable. I think I got them from Cyclorise but I can't find them on their site any more. Available in several colours if you find them, just visible in this shot.
Posted : 15/11/2018 5:19 pm
I stand corrected. You're right now I think about it.
Re-usable cable ends! What a time to be alive! 😉
Posted : 15/11/2018 5:24 pm
Ferrules, that's the thingamajigs
What are the plastic wotsits you stick on the end of the outers called?
Posted : 15/11/2018 5:54 pm
Them's ferrules as well Ben. A quick search shows this is what's in a Shimano gear cable set:
Shimano SIS Gear Cable Kit includes :
2 x Shimano Outer SIS Gear Cables. Length : 600mm.
3 x Shimano Outer SIS Gear Cables. Length : 320mm.
2 x Galvanised inner Gear cables. Length : 2275mm. 10 x Plastic Outer Cable Ferrules.
2 x Cable ends. Ideal for MTB / Hybrid use.
Posted : 15/11/2018 5:59 pm
I tried contacting that seller on ebay but they don't take questions for some reason. I was going to ask if they have SS rather than galvanised cables
The outer cable at less than a tenner for 10m seems like good value. Is the Fibrax stuff as good as anything else?
Posted : 16/11/2018 2:36 pm
Don't buy the FWE stuff from evans it's p-p-p-p-p-pony, I did and I regret every last shiny penny pound I spent.
Posted : 16/11/2018 2:41 pm
Only if it's decent stuff.
Posted : 16/11/2018 2:42 pm
this is what I got.  https://www.ebay.co.uk/itm/252485394691 10 mtb ended "slick stainless steel"
I ended up getting 30m of outer, £25. as that put it over the threshold for a fiver off, so 30m for £20, rather than 10 for £10
Posted : 16/11/2018 2:43 pm
Only if it’s decent stuff.
I think that's what he's asking with his second sentence!
last time this came u there were a couple of people saying the Clarks stuff was perfectly good.  I bought this assuming it can't be worse than that.  We'll see!
It's probably exactly the same stuff.  Can't be worth too many people making it!
Posted : 16/11/2018 2:45 pm
Decathlon sell an inner cable coated with what appears to be a similar finish to the expensive shimano xtr inners for a lot less ££.
Posted : 16/11/2018 2:52 pm
I have big boxes of Clarks lined gear and brake outer cable. As far as I can tell, it's as good as anything else I've ever used and, having loads of it means I tend to change it more often which I think is more important than using posh cables.
I've never bulk-bought inners (despite using more of it than I would like!) so am interested in good, cheap options here.
Posted : 16/11/2018 3:11 pm
Not cheap at £3 each though!!
Posted : 16/11/2018 3:13 pm
I’ve never bulk-bought inners
they're one of those things that if you one, you need one. £6 in Evans/LBS bought singly, and if you're buying online so you never have to pay that, you may as well get a few in.
Posted : 16/11/2018 3:42 pm
I buy these for inners and a job lot of SP41 from where ever's cheapest.
Posted : 16/11/2018 4:10 pm
Last time I stocked up I gambled on Clarks outer from eBay and 100 gear cables.
Same as above,as I've got loads I change it when it needs doing and have better shifting because of it
Posted : 16/11/2018 4:17 pm
I bought a job lot of Shimano SIS SP # outer with a plastic ferrule each end, they are one length 30cms, happy to sell them on at 10 pence each plus postage or collect
Send me a message on here if interested
Posted : 17/11/2018 5:39 pm
Does anyone put anything over the exposed cable at the mech? It’s the only place crap can get in now running full length outer, so I was thinking of zip tie a bit of road inner tube, or is this a stupid idea that will get me laughed off the hill side?
Posted : 17/11/2018 6:42 pm
I use a waterproof cable kit from wiggle, has ferrules with pipes on the end you can slip a pipe over to cover exposed cable.
Posted : 17/11/2018 11:33 pm
I buy from Uber bikes and you get a nice choice of colours
Posted : 18/11/2018 8:54 am
You can get a 50m roll of SP41 from Merlin for £54.50
Posted : 18/11/2018 9:07 am
Any Black Friday gems about?
Posted : 23/11/2018 11:45 pm
I always buy stainless inners, they are just smoother & stay smoother longer.
Even cheap outer can be made to work well by squaring off the cut ends with the face of an angle grinder disc. I cut it with an angle grinder with a 2mm thick blade these days, it does a much cleaner job.
And use a small drill bit to clean out the inner nylon sleeve, it makes a big difference.
Posted : 24/11/2018 12:10 am
