Sticky XT Caliper P...
[Closed] Sticky XT Caliper Piston, help
[#1552652]
seems to be getting worse and worse I need to do something about it.
So what do I do?
Wheel and pads out, coax said sticky piston out (not fully), in, out, in out...
clean, with what?
and lube with what?
I read on here recently wd40 gt85 will make the seals swell
so what's best?
Posted : 28/04/2010 10:24 am
shimano brake oil. 🙂
Posted : 28/04/2010 10:26 am
makes sense 8)
I should have put in my post that it was probably a silly question 😳
Posted : 28/04/2010 10:27 am
I clean the edge of the piston with disc brake cleaner (muck off do a big can) or IPA or meths and use an old toothbrush to get right around it, then push piston back in and repeat until no more muck shows on the piston edges. does seem to do the trick if they get a bit sticky.
Posted : 28/04/2010 10:30 am
i used go kart disc cleaner (probably too strong/ oil based) and it wrecked my shimano seals; hence my suggestion of the oil.
I found that i had to ease the pistonback into use.
held the opposite side in and pumped the lever to get the sticky side out, gave it a clean and a lube. pushed them back in and repeated. was better but not fixed; rode it for a few hours and repeated and it seemed to come back to life.
Posted : 28/04/2010 10:35 am
 FOG
All good advice but be prepared, this will happen again!However if use the various dodges recommended above you will be able to sort it unlike some other brands of brakes I could mention, oh! alright I will mention-Formulas.
Posted : 28/04/2010 10:37 am
thanks all
Posted : 28/04/2010 10:40 am
