Sticky Sram x9 10 s...
[Closed] Sticky Sram x9 10 speed shifters
[#4739556]
Hello,
Having real sticky problems with the above shifter. Once pushed it sticks, it does change gear but the paddle sticks in place. I've tried lubing it. Anyone know of any cures before I tear it apart and probably make it worse.
Thanks,
Matt
Posted : 11/01/2013 4:14 pm
SRAM have acknowledged this issue and have since updated the levers to run on ball bearings as opposed to bushes - as long as you're within 2 years old (I think), you'll be able to get them swapped for the new type.
I would not open the shifter up to try and fix it.......!
Posted : 11/01/2013 4:47 pm
Mine started having that exact problem a couple of weeks ago! Bought it from CRC last February. When/where did SRAM admit liability and offer replacements?
Posted : 11/01/2013 5:04 pm
Bin them. I had the same and no matter what I did I could not get them to work properly. Spent ages stripping cleaning and re greasing.
I had 12 year old shimano lx that worked better than 1 year old sram.
Posted : 11/01/2013 5:12 pm
Don't bin them - just send them back via a Fishers dealer and get new ones! Just tell them what's happening and request them to be replaced with the new ball-bearing type.
http://www.bikerumor.com/2011/12/13/sram-x9-triggers-get-ball-bearings-in-2012/
Posted : 11/01/2013 5:24 pm
Thanks for the replies. I've been stung then I bought them off ebay! XT from now on then.
Matt Lewis
Posted : 11/01/2013 8:25 pm
Had this too, lube makes it worse. I took the little rubber grommet/cable port cover off and sprayed with GT85, good soaking and all good. Just re-spray every other ride. See how long they last.
Posted : 11/01/2013 9:03 pm
Have you checked the cable? The most common cause of sticking lever I've seen is a kinked cable inside the shifter. Try pulling the cable out. Cables can occasionally become kinked 1cm from the nipple in SRAM shifters. I've never figured out why though. They still shift but but the lever doesn't return.
The upgraded replacements sound like the next option.
You could dismantle and check the spring on the lever. I've never pulled apart an X9 but I have pulled apart a few other SRAM shifters. They all seem to have a v-shaped spring. This can slip out of it's grove. Bending it back a little and then refitting fixes the problem for a few months. If you do pull it apart I recommend you use good quality screwdrivers and press them fully into the screw heads - they round if you're not careful. Take the housing apart very slowly - you want to open it so the springs all remain seated. If you open it the wrong way up everything pings off over the kitchen and you'll spend hours trying to work out how it goes back together!
Posted : 11/01/2013 10:45 pm
