Noticed lever wasn't returning properly. Took the lever apart and it was all I could do to get the piston out - I had to push (hard) with an allen key from the hose end. Couldn't see anything visibly wrong with it though
I have ordered a replacement - hopefully this will sort it
anyone else had this?
https://www.bikeinn.com/bike/sram-spare-parts-kit-piston-maneta-guide-rsc-ultimate/136336069/p?
Posted : 27/05/2017 5:29 pm
Yes it is a common problem on all versions of Guides. I sanded a tenth of a mm off the diameter of the piston and reassembled with sram dot grease. Has been ok since. For some reason the plastic seems to swell slightly with age/heat and get stuck.
Posted : 27/05/2017 10:53 pm
