Sticky Pushlock
[Closed] Sticky Pushlock
[#1012673]
Having a few problems with my pushlock on a pair of revelations.
Seems really sticky, release at the bars, and quite oftern have to reach down and give it a bit of a flick to get it moving, dead annoying!
Happened to anyone else?
oh they are brand new btw.
Posted : 04/11/2009 5:22 pm
snap - 2 week old forks
Posted : 04/11/2009 5:23 pm
Hmm well hopefully someone has a answer!
Posted : 04/11/2009 5:26 pm
Only time I have ever had this problem, it was a cable issue. Not sure if it was something getting stuck or just dirty but I took the cable out, cleaned it all up, shortened it (as it was way too long) and it has worked fine since.
Posted : 04/11/2009 5:50 pm
Had the same problem turned out to be some shit in the gubbins, common problem according to tftuned
Posted : 04/11/2009 5:53 pm
Same problem here. Seems to me that it only fully releases when the forks are at full extension. Any compression and it stays down.
Posted : 04/11/2009 6:09 pm
My poplock snapped the cable outer right under the poplock lever on the first outing. Doesn't look like theres a ferule on there to spread the load. I'm going to convert back to a fork-top dial
Posted : 04/11/2009 6:48 pm
Surfr - Could I possibly have your fork top dial for the pop-lock, if it fits a Reba. 😆
Posted : 04/11/2009 7:05 pm
hmm well im reluctent to accept that it is dirt considering how new the forks are, but will try shortening and lubbing the cable.
One thing that makes me a bit sceptical about this is the slack that shows becuase the dial hasnt taken it up.
Posted : 04/11/2009 7:18 pm
fingers it's an '09 Reba Race and you are welcome to it once I've made the change. Not doing it right away though. Other jobs on the list first.
Posted : 04/11/2009 7:20 pm
cheers, please keep me posted...
Posted : 05/11/2009 1:57 pm
New forks, difficult to apply and slow to release.
Posted : 05/11/2009 6:39 pm
Mine seems to be the same as chatsworthmunsters, only have a problem releasing when under compression of any sort!
Posted : 05/11/2009 6:57 pm
Yeah mine with a poploc is the same, it will occasionally stick if released with the forks compressed. With the forks at full extension it releases every time so I don't think it's a cable issue.
I personally don't find it a problem though because the next bump you hit releases it or a quick tug on the bars sorts it. I think it's just the nature of the beast.
Posted : 05/11/2009 7:05 pm
