Sticker removal
[Closed] Sticker removal
[#7745402]
Evening all,
What's the best way to remove stickers from frames and wheels, going to go all minimalist.
Any advice appreciated
Tar
Posted : 03/04/2016 8:55 pm
In my experience neat muc-off left too long......
Posted : 03/04/2016 8:56 pm
Get the surface stuff of by pealing and the sticky residue with surgical spirits. Works for us
Posted : 03/04/2016 8:57 pm
Hot water and just peel off.
Posted : 03/04/2016 9:04 pm
[img] ?boundedSize=310[/img]
job done
Posted : 03/04/2016 9:06 pm
Used to use a hair drier to remove badges from cars - you will have differing levels of success though depending on how it was applied to a bike..
Posted : 03/04/2016 9:08 pm
Cooking oil can be good for some adhesives that solvents won't cut through.
Posted : 03/04/2016 9:22 pm
gt-85 removes the sticky residue
Posted : 04/04/2016 2:23 pm
Any oil will break down adhesives.
Best to warm the sticker with a hair dryer and peel off as much as poss.
A bit of oil to removed the adhesive and ad some backing soda if they're being stubborn.
Posted : 04/04/2016 2:28 pm
Goo Gone
http://www.amazon.co.uk/Goo-Gone-Large-Sticker-lipstick-remover/dp/B003I6JPFY
Used it for years for sticker removal! Cannot be arsed messing around with homemade options.
Posted : 04/04/2016 2:30 pm
Peel sticker off, remove any adhesive residue with Autoglym Tar and bug remover.
Posted : 04/04/2016 2:42 pm
SLight hijack but is there anything that will remove decals as opposed to stickers
e.g. frame decals on top of the paintwork but not peelable as such
Posted : 04/04/2016 3:15 pm
Possibly heat them first, Acetone?
Posted : 05/04/2016 8:58 am
Whatever the decals on a 1st gen Ti456 were, came off with nail varnish remover or meths.
I'm not sure what I'd trust on a painted or varnished frame though.
Posted : 05/04/2016 9:27 am
I spent about two hours last night de-stickering a Corima tri-spoke wheel. I tried acetone but it would not touch them so ended up chipping away at them with a credit card. The decals would not peel (they seemed to be similar to the old airfix type that you had to soak in water).
It was a right pain in the arse but the wheel looks great now.
Posted : 05/04/2016 10:18 am
WD40 is also quite good. Carb or brake cleaner if you're brave !
Posted : 05/04/2016 10:32 am
Are you sure it's not a crack?
Posted : 05/04/2016 10:59 am
