HI all,
whats the best way to get the sticky stuff from stickers off your frame?
ta
Ben
Use some isopropyl alchohol, will take it striaght off.
white spirits and elbow grease, if you use heat first there is normally much less glue left behind.
goes back to removing miles of vinyl from a 7 meter banner 😕
Blow torch.
already peeled them off - just the glue stuff left now! will nail varnish remover work??
or disc brake cleaner??
wd40 or gt85 will work. Then blowtorch
+1 for WD40, infact it's all it's good for !
Try [url= http://www.lakeland.co.uk/sticky-stuff-remover/F/productimage/8976?returnURL=/sticky-stuff-remover/F/product/8976?src=gpsolANDsq=sticky+stuff+removerANDsrc=gpsolANDsq=sticky+stuff+remover ]STICKY STUFF REMOVER[/url]
