I' min the market for a new 50mm or so stem, must me nice and stiff without nasty creaks! Choices are:
Thompson elite 4x 50mm
Easton haven 55mm
Hope AM / FR 50mm
So, STW do your worst...
Haven
Funn Funnduro 45mm
Less is more
+1 for Haven
the bar clamping system is much better than Thomson.
Not had any creaks from my Thomson in that length, it looks great as well, super boxy and chunky.
I'm leaning towards the Haven at the moment, Thompson second.
Has to be 50mm minimum so the Funn is no good.
Renthal Apex?
That's a nice bit of machining. Couldn't say whether it will creak or not!
http://www.chainreactioncycles.com/crank-brothers-iodine-1-stem/rp-prod68927
I have one of these on my HT, it's stupidly good for the money.
I' heard the apex creaks, so that's out. As for the coding, really good value but fugly!
jimw - Member
+1 for Haventhe bar clamping system is much better than Thomson.
Whats so different?
Need a new bar to go with it too, will it not?
The haven instructions are clamp top ones fully down then the bottom to spec.
Syntace Megaforce 2.
Seriously, google it. Doesn't get any lighter or more subtle.
My Renthal is so creaky it's almost musical.
Wow the syntace isn't cheap!
Easton Haven. Very nicely machined and stiffer than the Thomson and without the creaking. The Hope is probably stiffer but it's also got garish graphics.
[url= http://singletrackworld.com/forum/topic/fs-50mm-easton-haven-stem-whyte-750mm-bars-superstar-alpine-160mm-rotors ]I happen to be selling the Haven stem in 55mm flavour..[/url]
RAceface blamed a Funduro stem for breaking my mate's bars. I have no idea if it was true, or not, but still.
Stems are pretty simple components tbh, I have a Pro FRS on one bike, a nicer KCNC on another, had a Haven before, can I tell any difference without scales? Nope.
My apex doesn't creak. It needs to be clamped in a similar way as described above for the Haven.
I believe it is the renthal duo is prone to creaking,
I also have a straight line 50 mm stem. Not the prettiest, but sturdy. Also clamps like the haven, though not as good looking.
El guapo cortez from on one.
Staitline in a garish colour.
Renthal Apex.Great quality and no creaks at all.
I've an apex too, lovely stem and easily the lightest weight of all the ones mentioned here. No creaks.
Looks like it's the haven then, thanks guys.
Another vote for the Syntace Mega Force. Ten year warranty 😉 Totally silent.
Str, ever put a tape measure next to that stem?
No - maybe it's a 50mm.... 😀
definitely not 35mm!
Race Face Turbine 60mm, Super light @ 123g (lighter than Syntace) Quality to match Thomson and Hope. I have been using two of these of both of my bikes for last 2 years (no creaking). I have had both Hope and Thomson, this is every bit as good. This is my third and surplus, £35 posted
[URL= http://i282.photobucket.com/albums/kk243/covehustler/Turbine%20stem%201_zps9ij2qflk.jp g" target="_blank">
http://i282.photobucket.com/albums/kk243/covehustler/Turbine%20stem%201_zps9ij2qflk.jp g"/> [/IMG][/URL]
Not lighter than a Syntace. The 60mm Syntace is 127g. I run a 30 mm which is 107g. If you want to quote weights get your facts in order 😉
Erm, I *think* he has...
😳 Thinking about my 30mm stem there. 😳
Never mind the 4g weight penalty 😉
The Syntace Megaforce 2 stems are faultless.
Dunno if the Turbine matches other brands for quality - they had the breaking faceplate issue. Personally wouldn't touch one,
Also, the Turbine only goes down to 60mm as it's more of an XC/Tril type affair than the others mentioned.
Megaforce FTW (sounds like an 80's cartoon, that).
cokieEaston Haven. Very nicely machined and stiffer than the Thomson and without the creaking. The Hope is probably stiffer but it's also got garish graphics.
The Haven is nowhere near as stiff as the Thomson, I've had both. Sold my Thomson X4, bought a Haven. noticed how flexy it was and bought another Thomson.
+1 for Renthal Apex - no creaks and rock solid
Realised I've spent this entire thread pointing out errors without actually giving a recommendation.
Which is Thomson every time.
ran one of these for a few years now with no issues at all
http://www.on-one.co.uk/i/q/STOOCNC/on-one-ultralight-cnc-stem
Can't fault by Thomson X4's. Both are fine after a few years of use with no creaking etc.
Got a Renthal Apex here. No creaks, great stem. Replaced my Haven with it.
raceface diabolus D2....comes in the 50mm length and has a lifetime warranty.
its a bit heavier but is stiffer than Ron Jeremy on a good day!
gonzy - Memberraceface diabolus D2...its a bit heavier
A bit? 254g for the 50mm, which us 6g heavier than two Syntaces.
Burgtec MK2 Enduro stem?
