Steerer cutting
[Closed] Steerer cutting
[#4489210]
Can anyone recommend the best way and saw to cut a steerer to size?
I assume its measure, measure again...measure once more to be sure and a small hacksaw...not a jigsaw and just guess?!
Is there a recoomended saw blade for this type of cutting?
Also, do no manufactures put cutting sizes on steerers like they do on bars for cutting?
Posted : 23/10/2012 7:04 pm
 d4
Superstar do a cheap and cheerful cutting guide that fits in a vice or workmate, unless you know the exact length you want cut close to it 20-30mm from where you think you want it after "dry" fitting and use spacers to play around with height, then once you are sure trim down. Normal hacksaw blade will chop through it no problem. Never seen one with cutting marks.
Posted : 23/10/2012 7:14 pm
I always use a cheap pipe cutter , but a tiny bit at a time otherwise you can flare it , quick file after easier than hacksaw I think and always good straight cut
Posted : 23/10/2012 7:17 pm
Lbs..around a fiver...I've never done it when they do it so well
Thanks Dave - LBS might be the most sensible way me thinks...can't even put a shelf together properly!
Posted : 23/10/2012 7:26 pm
Under a tenner for a pipe cutter at B&Q. 2 seatposts/forks etc etc and you've made your money back!
Posted : 23/10/2012 7:29 pm
Masking/electric tape around the steerer to give you a straight edge to follow. Then add cutting implement of your choice. (I karate chop mine but lesser men might use a hacksaw or similiar)
Posted : 23/10/2012 7:31 pm
Hacksaw and an old stem. No worries.
Posted : 23/10/2012 7:33 pm
Pipe cutter ,standard hacksaw and a file. 5 mine job . Follow instructions of youtube
Hacksaw. If you are using spacers it is easy put the stem on first, tighten it in place and then spacers above. Put one less spacer than you need and the spacer acts as a guide for the cut so you get an even finish. The spacer will get some abrasion but you can turn it over and put it in the middle.
Posted : 23/10/2012 7:47 pm
Did just this on Saturday. Measure the old steerer if you're just replacing otherwise pre-assemble and measure and check THRICE!
Then use pipe cutter very gradually tighten the blade until the steerer end drops off. Then gently file a slight angle on the end of the steerer and you're done.
Take your time, check, carefully and don't rush it.
Posted : 23/10/2012 8:13 pm
Whatever you do, don't measure to the bottom of the stem and cut there.
Seriously - I know someone that did.
I just use an old stem and a hacksaw. Finish off with a half-round file. At the end of the day, it doesn't have to be perfectly straight.
Posted : 23/10/2012 8:18 pm
Oh and don't forget to allow for a vbrake hanger when measuring, I know someone that did that too.
And I had to buy new forks. Red face 🙁
Posted : 23/10/2012 8:21 pm
This. Fine toothed blade, and finish with a file.
Posted : 23/10/2012 8:39 pm
Got one of those Icetools cutting guide. Done 4 or 5 forks so it's paid for itself alredy. Finish off with a file.
Posted : 23/10/2012 9:53 pm
I've used cheap pipe cutters before but find they tend to wander on a pipe that big. it's hacksaw and spacers these days and it works fine
Posted : 23/10/2012 9:57 pm
I tried to use a junior hacksaw but gave up, so I used an angle grinder. It worked well and I got a really clean cut. Then I just filed down the burs. Will use a pipe cutter next time tho.
Posted : 23/10/2012 10:11 pm
There are options in between those two extremes 🙂
Posted : 23/10/2012 10:13 pm
Pipe cutter and file but if the LBS is £5 then go there.
Posted : 23/10/2012 10:16 pm
Did thid for the first time the other day. Fitted the fork with stem and spacers i inentded to use. The marked where i needed to cut. Took out the fork and fitted an old crappy stem to use as a straight edge. Cut using a junior hacksaw. Cleaned the inside of the steerer and fitted a star nut, pushing it using a hope head doctor and a rubber mallet!!!
Posted : 23/10/2012 10:20 pm
Ice tools cutting guide here. Easy and straight cuts!
Posted : 23/10/2012 11:54 pm
Whats wrong with an angle grinder? Takes 2 seconds.
Posted : 24/10/2012 12:07 am
Cutting guide and star-nut setting tool here, paid for itself many moons ago. Bear in mind you might want to adjust your stem position, so leave yourself some spare. Also, longer steerers are easier to sell on.
Posted : 24/10/2012 12:13 am
Cutting guide is the best way to do it - gets it dead straight and less cleanup.
Posted : 24/10/2012 12:15 am
A hacksaw works perfectly well and costs about £5.
Posted : 24/10/2012 9:35 am
