Steel Full Suspensi...
[Closed] Steel Full Suspension Bikes
I've recent purchased a short travel steel FS in the form of a Swarf contour, I bought one because the design features in my opinion are well thought out for the type of riding I do, I test rode one and it felt awesome and it feels right to support a smaller UK bike designer that's handbuilding in Scotland,.Oh yeah and its ****ing beautiful.
Whoever said that people buy with their heart was right, there are many aspects to what makes a great bike..what they are constructed of is just one factor. If the latest Santa Cruz carbon bling is your things knock yourself out, they just dont ignite any passion in me...I prefer steel, just because. Go ride one and make your own mind up.
For what its worth: I didn't rate STW Wills Contour review, Trevor@ Enduro Mag review was more inline with the bike I test rode.
Posted : 07/10/2018 9:41 pm
Well let's have some pics then!
Posted : 07/10/2018 10:04 pm
Work in progress.
Posted : 07/10/2018 10:24 pm
With the paint and bits on, you big tease
Posted : 07/10/2018 10:46 pm
All in good time my man,.. it's still getting the finishing touches @Swarf( and I'm still arseing about collecting parts)
Posted : 07/10/2018 10:59 pm
 duir
Joe from Starling explains frame stiffness and why a bit of give us better. He’s an aerospace engineer with lots of experience with Carbon fibre, so probably knows what he is on about.
I have a Swoop on order, the custom geometry was a big thumbs up but as I approach middle age and have a bit of arthritis I wanted a more compliant frame than my usual super stiff alloy bikes. That’s what made me look at steel.  I have been impressed by the feel of my steel hardtail and wanted a full sus version of that.
I had never thought about lateral stiffness before I saw this video but it makes sense...........we shall shall see!
L https://m.facebook.com/story.php?story_fbid=1380399148727271&id=593631864070674&refsrc=https%3A%2F%2Fm.facebook.com%2FStarlingCycles%2Fvideos%2F1380399148727271%2F&_rdr
Posted : 07/10/2018 11:28 pm
That starling video is irritating me.
A force at 45deg is 1/√2 =0.707, not a half, that would be 30deg?
He's right though, there isn't a quantifiable optimum (that's known of anyway), but some is better than either none or too much. Even the big brands are realising this, saw a press release the other day claiming the new bike was indeed less stiff than the old model.
Hols2's car analogy is wrong on two points, one a car can control its suspension in all sorts of axis and angles, a bike just has a 2d axle path and axle rotation, a car has vertical, lateral, fore/aft, axial and camber components to it's movement. So a lot of the sideways give is already there. Secondly cars have rubber bushes designed to take out the small high frequency movements which effect grip. Cars without bushes or with stiffer bushes trade more feedback for less compliance.
Posted : 08/10/2018 12:24 am
Road cars do this to reduce noise, vibration, and harshness, not for grip. Race cars don't do this. One of the first things that production car racers do is to replace the rubber bushings with rose joints, which have no give. This makes them unbearably noisy because all the vibrations from the road are transferred directly to the cabin. The other big thing with turning a road car into a track car is a roll cage, which will be attached to the suspension pick ups to increase the stiffness of the body shell. Of course the rules require a cage on safety grounds, but the main concern in designing the cage will be maximizing the stiffness of the body shell. Suspension performance is improved by mounting the suspension to very rigid mounts. You want the springs and dampers to control the movement of the wheels, not flex in the chassis or bushings.
Posted : 08/10/2018 2:07 am
 duir
He’s right though, there isn’t a quantifiable optimum (that’s known of anyway), but some is better than either none or too much. Even the big brands are realising this, saw a press release the other day claiming the new bike was indeed less stiff than the old model.
Hols2’s car analogy is wrong on two points, one a car can control its suspension in all sorts of axis and angles, a bike just has a 2d axle path and axle rotation, a car has vertical, lateral, fore/aft, axial and camber components to it’s movement. So a lot of the sideways give is already there. Secondly cars have rubber bushes designed to take out the small high frequency movements which effect grip. Cars without bushes or with stiffer bushes trade more feedback for less compliance.
Maybe you should offer Joe the benefit of your far superior engineering knowledge? He seems pretty open to input and maybe he could learn a thing or 2 about frame building from you?
Hmm that said, his bikes do get rave reviews for both build and ride quality and he used to be an aerospace engineer so maybe he knows his stuff after all?
Posted : 08/10/2018 3:51 am
The disagreement here is not about ride quality. It's about the claim that a steel frame will flex so much that it will enhance the ability of a 6" travel suspension frame to keep its rear wheel tracking the ground. That's marketing bollocks.
The frames are steel because they'd have to be built in Asia if they were aluminium, so the marketing benefit of a boutique brand would be lost. To make a steel frame as stiff as an aluminium one would be very heavy, so the marketing guys came up with "breathing with the trails" as a "it's not a bug, it's a feature" comeback.
You can change the feel of a bike by changing tyres, tweaking tyre pressures, adjusting spoke tension, changing wheels, adjusting the suspension air pressures/spring rate/preload/damping etc, changing handlebars and grips, changing seatpost and saddle, etc. Unless you do really exhaustive comparison testing of all those things to isolate the effect of the frame material, you really don't know what it is that's causing one bike to feel harsher than another. FFS, if you change the tyre pressures by 5 psi, the bike can go from horrible to great and vice-versa.
I did ask kelvin to post his notes from all his exhaustive testing of prototypes, but he must have been busy, I haven't seen anything yet.
Posted : 08/10/2018 7:01 am
On a two wheeler when it leant over the bump forces will be vertical but the suspension travel will be  at an angle.  Especially with telescopic forks this leads to binding in the suspension components and thus reduced small bump compliance
Racing motorcycles found this to be a limiting factor quite a while ago and had to actually reduce stiffness in frames as the superstiff frames they had developed led to adverse effects when hitting bumps when leaned right over - mainly chatter IIRC
Of course this is also exacerbated by the very low profile tyres used which have greater lateral stiffness
This effect must be present in MTBs to some extent - whetherit actually affects most of us I doubt.
So some lateral flex in frames will certainly have an effect on  feel and performance when hitting bumps when leaned over and may well make it feel less harsh
My ti bike is incredibly harsh showing its not all about materials by any means - it has short thick and straight chainstays and seatstays which is where the harshness comes from.
Posted : 08/10/2018 7:22 am
I just love the slim and simple shapes of steel frames and I particularly like the way the top tube and seatstays line up on the Contour, beautiful. And I also like the idea of owning a bike from a British company. But I'm a tight Yorkshireman so I'll be sticking with my MK1 Rocket till there are more on the 2nd hand market...
And I've got a City and Guilds in hairdressing so I'm qualified to judge style, shape and colour 😉
Posted : 08/10/2018 7:43 am
When I'm riding a bike, I don't care how it looks. I'm the guy with zip ties holding all the brake hoses and gear cables on because it guarantees they stay put even if it looks like shit. I do enjoy nice looking bikes, but only for looking at, not for riding. The point here is that people are spouting marketing bollocks about steel frames improving the ability of the rear suspension to keep the wheels tracking the ground because of "breathing with the trail". I call bullshit on that and I'm still waiting for kelvin to post his extensive notes from all the prototypes he rode while perfecting the breathing thing.
Posted : 08/10/2018 8:36 am
The frames are steel because they’d have to be built in Asia if they were aluminium
no they wouldnt orange build a shedload of non steel frames maybe someone should tell them
Posted : 08/10/2018 9:00 am
Orange build their frames by welding together pieces of sheet metal. They don't do the complex hydroforming stuff that the Asian manufacturers do because it would be mega-expensive to tool up for that. Correct me if I'm wrong, but I think Cotic have their aluminium rear ends manufactured in Taiwan. Building aluminium bikes is a bit trickier than steel, AFAIK, so doing the aluminium bits in the UK would need investment in factory equipment beyond what is needed for steel. Hence the outsourcing to Asia. It's not that it can't be done in the UK, it's just that it wouldn't be economical for a boutique manufacturer.
Posted : 08/10/2018 9:33 am
Very little idea about frame building, its the trigonometry that I think is wrong. A force applied at 45deg is balanced by two forces at 45deg to it but perpendicular  to each other equal to 1/√2 of the original force.
Also if you were to measure forces in a corner you would have gravity (vertically down), the cornering force (centripetally) on top of that, and impacts from the ground at any angle (they might be vertical, they could be horizontal in any direction)
Posted : 08/10/2018 10:00 am
“It’s about the claim that a steel frame will flex so much that it will enhance the ability of a 6″ travel suspension frame to keep its rear wheel tracking the ground. That’s marketing bollocks.”
If you remove your massive head from your arse, take your blinkers off and actually try to learn something, you’ll quickly find that the chassis stiffness is critical to the handling behaviour of ALL vehicles and for two-wheeled vehicles it is an established fact that too much longitudinal torsional stiffness has a negative impact on cornering grip and predictability.
Just actually THINK about it. What the hell do you think happens when you take a 3kg frame made of carbon, aluminium or steel, attach it to some wheels and then have 80+kg of human levering most of their mass through a lever attached to the BB, lean it right on its side so the suspension isn’t working in the right direction and then hammer it through a bumpy corner pulling well over 1G? I mean, how obvious is it to anyone with an ounce of engineering intuition that the frame will flex and twist and that that will help it grip the ground?
I’m no great rider and I can tell the difference between 20 and 22psi in my front tyre, it’s really obvious. And that’s on a bike with 160mm forks. Watch a super slow-mo of a DH bike in a corner and it’s twisting and bending.
This NOT about steel vs other materials - it’s about how you use them. Steel is vastly stiffer than aluminium as a material. A bike that is too stiff is not good in rough trails. The fork needs to be stiff not to bind. The rear suspension components need to be stiff and only move as designed. But BB to head tube needs to have some perceptible give under riding loads.
I will never cease to be amazed at how some people struggle to understand the complexity of real world scenarios. I mean, if you’ve got 160mm of travel why does the tyre pressure matter, or the wheel stiffness, or the bar stiffness or the grips? Come on, wake the **** up!
Posted : 08/10/2018 10:08 am
All the cotic frames up until this one weren't UK made, so on that front they could have had them made from aluminium if they wanted. Their first FS bike was aluminium, so they could have had them made from aluminium if they wanted. There's clearly something about the steel beyond 'make it in the UK'. From the original rocket tech stuff it's initially about getting the main pivots/seat tube stiff enough, but you're perhaps a bit off saying it's just about UK manufacture.
Posted : 08/10/2018 10:13 am
The combined forces must run from the center of mass to the tyre contact patch otherwise you would fall off. Unless your body is massively misaligned with the bike (i.e. you have the bike vertical and your body hanging off to the inside of the corner), the forces in a corner will still be running close to through the centerline of the bike, so the suspension and frame shouldn't be twisted massively.
If you have the bike leaned right over and hit a bump hard enough to twist the frame to the same order of magnitude as the suspension travel (i.e you are cornering on the flat with the bike laid right over and run across a large root or rock), then you have awesome ninja MTB skills and I don't think it will make any difference whether you ride a steel or aluminium frame. I'm just a mere mortal, so trying something like that would see me skidding down the trail on my arse.
Posted : 08/10/2018 10:18 am
"Unless your body is massively misaligned with the bike (i.e. you have the bike vertical and your body hanging off to the inside of the corner), the forces in a corner will still be running close to through the centerline of the bike, so the suspension and frame shouldn’t be twisted massively."
There's your first mistake. When you ride a turn on a MTB the bike is leant over further than the rider and the rider places most of their weight through the outside pedal and the inside grip. A good rider will constantly weight and unweight the bike to find grip, unloading before turning and then placing maximum load at the moment of highest lateral acceleration. That's how you corner fast, you generate momentary downforce when the most grip is needed. You cannot do this as effectively if your centre of mass stays in the same plane as the centreline of the wheels.
"If you have the bike leaned right over and hit a bump hard enough to twist the frame to the same order of magnitude as the suspension travel "
The twist in the frame doesn't need to be of the same order of magnitude as the suspension travel for it to matter. Not even close. How much does a DH tyre carcass conform mid-corner? And yet riders care about their tyre pressure to less than 1psi?
Posted : 08/10/2018 10:57 am
…your bike is broken. Try another straw man… or except that, no matter what the material, stiffness in different parts of a frame are often tuned, rather than the same ultimate stiffness all around being the goal.
Posted : 08/10/2018 11:00 am
That's not what's being claimed, really.
Suspension only moves up and down, not side to side.  When riding down a rocky trail, the rocks aren't all neat perpendicular steps - they are strewn haphazardly all over the place.  The surfaces your wheels hit are sloping at all angles.  These will present sideways forces to your wheels.  Much of that is absorbed by tyres and probably most of it by the rims.  That's why many complain that carbon wheels are 'too stiff'.  If too much of this sideways force is transmitted to the bike it's going to be pulled sideways all over the place as you ride.  From your moving frame of reference, this would feel like the bike being pulled all over the place.  On a suspension bike the swingarm probably twists about the fore-aft axis too, which would also absorb some sideways impacts. When the bike is leant over, this flex would also be helpful in stopping the bike jumping around too much.  I'm guessing this would be the biggest but not the only advantage of having a little twisting flex available in the frame.  I'm sure there are videos somewhere of frame flex in a FS.
I am not an engineer but I do have a Physics degree.  And whenever someone makes absolute pronouncements like you have hols2 I am immediately sceptical!
EDIT That's not to say that stiffness wouldn't give benefits elsewhere - like power transfer when pedalling etc.  So it comes down to where you ride and what you like.  Just test the bike and pick the one that feels best.
Posted : 08/10/2018 11:30 am
The center of mass of the combined bike and rider has to stay reasonably closely aligned with the tyre contact patches or else the bike will rotate around the contact patch and you will crash. You adjust for small changes in this over bumps through the steering and adjusting your body weight, but you can't have the sum of the forces massively misaligned or you will crash. That's just brute physics.
My scepticism is that the flex in a steel frame will be so much bigger than in an aluminium or carbon fiber frame that it will assist the rear wheel in tracking the ground in a bike with 6" of rear suspension travel. I'm not saying frames don't flex, just that they don't flex several inches. I'm also not saying that the resonance properties aren't different, just that I don't believe that the supposed extra flex in a steel frame is going to have a positive effect on the rear suspension.
A lot more than a steel top tube does. Watch some videos, it's amazing how much tyres roll around. Or just pump your tyres up to 100 psi and see how it feels when they don't flex.
Although, to be fair, my first suspension bike was a 1999 Spesh FSR. Goddam that thing flexed a lot. Pedalled well, but was always worried it would snap in half. It eventually snapped in half on the cast section at the front of the chainstay, just behind the lower pivot. Great little bike, but that flex was really disconcerting.
Posted : 08/10/2018 12:25 pm
I’m not saying frames don’t flex, just that they don’t flex several inches
Well, we can all agree with that strawman. What a waste of time.
Posted : 08/10/2018 12:32 pm
That strawman was what the disagreement was about. So when can we expect you to post all your detailed technical records of the prototype testing you like to boast about?
Posted : 08/10/2018 12:42 pm
I'll repeat myself…
I’m a very average rider. My notes would be something like “whoop” or “woah”…of little use to anyone.
Feel free to …
… whatever.
If you want to believe that no one is doing real world testing, including tuning the stiffness of different parts of a frame, no matter what materials they are using, so be it. Why should I care?
Posted : 08/10/2018 12:47 pm
So "breathing with the trail" is just some bullshit someone made up?
Edit. Another sneaky stealth edit there kelvin.
Posted : 08/10/2018 12:50 pm
Time waster.
Posted : 08/10/2018 12:51 pm
So it is just marketing bollocks then?
Posted : 08/10/2018 12:52 pm
Descriptive words are wasted on you.
Posted : 08/10/2018 12:56 pm
No, nothing will be wasted. They will be saved and recycled. Fire away.
Posted : 08/10/2018 1:03 pm
This thread has reminded me that I used to really enjoy long analytical debates about how mountain bikes work (or don't). Since getting the FlareMax though, I find that I've lost all interest. I don't know why it works. I'm not entirely convinced that Cy fully understands why it works. But work it most definitely does.
Are all great mountain bikes made of steel? Of course not. It just so happens that in over 40 years of riding all my favourite bikes (road, hardtail, fat and now full-suss) happened to be steel. But that may be coincidence or it may be that I like the look and that biases me towards them. Either way, I'm prefectly happy to accept that there are great bikes made of aluminium, carbon and titianiun and if that's your bag, knock yourself out.
I can't really adress the OP's original question though as I can't really understand why anybody would care about 2lb here or there on the frame weight. My weight varies by that much from day to day (and during a day). Heck it probably varies by that much during a long ride (and more when you factor in the water that I'm drinking), yet I don't notice it. So it's not a matter of whether the "advantages" of steel outweigh the weight penalty for me as the weight penalty is simply too small for me to be able to detect. Getting the right tyres, the right pressures and getting your suspension set up properly for the trails you are riding are all so much more important that a few lb on the weight of the bike.
Posted : 08/10/2018 1:05 pm
Fire away.
Others have tried, I'm not bothering to waste any more time on you.
I can’t really understand why anybody would care about 2lb here or there on the frame weight.
This has been done to death. You don't notice it much on your body but it is noticeable to many people on the bike due to the way some people move the bike around as they ride. To me, 2lbs on the frame is a lot. On its own it's noticeable but if you want a light bike all the components need to be light. Altogether they make a huge difference. You may not like it, but you might - that's why there is a choice on the market today. And it's not a problem.
Posted : 08/10/2018 1:08 pm
Oh dear, are you angry about something? Hope it wasn't anything I said.
I don’t know why it works. I’m not entirely convinced that Cy fully understands why it works.
You haven't been paying attention. It's because "breathing with the trail."
Posted : 08/10/2018 1:10 pm
Funnily enough I don't mind the “breathing with the trail”. Yes, of course, it's a bit of marketing speak. Trying to use a nice descriptive phrase instead of equally meaningless numbers. But I can kind of see where it comes from. Not that steel bikes are the only ones to do this. My old 26" Five was a flexy old thing and that was part of its appeal.
@molgrips it's a fair point. To be honest we've probably done most of it to death really. I do think it depends a fair bit on how you ride. I really don't notice a couple of lb on the frame weight. For example, if I had a bottle on the bike I couldn't tell (in a blind test) whether it was full or empty. I'm definitely "old skool XC" though. Other people, who throw the bike around more than me, may be able to tell, which is fine. For them, bike weight is important, but for me, it really is irrelevant (within fairly broad limits). Some of my favourite bikes were the heaviest, but again that's probably because I like bulldozing through suff.
Posted : 08/10/2018 1:25 pm
all except bump forces - they art vertically ( or slightly off it the bump is uneven)
All the other forces act thru the line from cog to contact patch but hit a bump - it kicks the wheel vertically upwards.
Posted : 08/10/2018 1:26 pm
hit a bump – it kicks the wheel vertically upwards.
Yes, the rider needs to make adjustments to steering and body position over bumpy corners or they will crash. Thing is, we do this without even realizing what we are doing. If we had to do it consciously, we would react too slowly and would crash.
Posted : 08/10/2018 1:34 pm
Crikey the Big Hitters have been busy on this thread!
Posted : 08/10/2018 1:43 pm
Hols - and that is where lateral compliance in the frame helps the bike be more settled.  As I said above in the motorcycle world they found that you could end up with frames that are two laterally stiff and it led to chatter so ducatis amongst others actually reduced lateral stiffness of their frames to keep the wheels on the ground more.
Posted : 08/10/2018 1:48 pm
is the flounce in full bounce you reckon
Posted : 08/10/2018 1:49 pm
So “breathing with the trail” is just some bullshit someone made up?
Well of course, but it's hardly a terrible bit of marketing Woo, I've seen worse.
You mentioned earlier that you are a Structural Engineer hols, why not actually analyse the differnces in behaviour of these structural elements?
You could work out the respective section properties for say a 32mm OD / 0.8mm thk steel tube and the same for a 55mm OD / 2mm thk Aluminium tube and work through their respective behavious when subjected to simple bending and torque load cases, just to see how much deflection you'd be likely to see and at what point each tube would go plastic (Say on a 600mm long tube?) work out the weight differences and then at least you've quantified the actual differences in structural terms.
How how the properties of a downtube and top tube contribute to a given "Bicycle Chasis" as a dynamic structure has a whole heap of additional analysis for an interested individual but probably massive overkill for anyone not actually making one...
Of course without that comparison you're simply casting doubt on the claims made by Cotic for the frame without really knowing how it actually behaves...
Personally I don't believe a bicycle is subject to perfectly symetrical loading in a single plane so there is some merit to the idea that the frame as a structure which provides some degree of elastic response when subjected to side loads or torque along its length may have benefits, or that some elements (say a swingarm) being stiffer than others (say the front triangle) could help the ride in some way... Discuss (even more).
Posted : 08/10/2018 1:54 pm
No, I said I studied engineering. I hated it and got a degree in political philosophy instead, intending to become a journalist. Instead I got a job as a technical writer for a company that had contracts with some well-known Asian companies. My job was to work with engineers who were posted to European subsidiaries and help them sort out their English technical documentation. Not full on technical research, but more like sales material targeted at other engineers. Some of it was cool. I worked with guys who designed nuclear power plants and the control systems for the early Prius, but most of it was mundane stuff like factory automation equipment and car parts. My bosses didn't know the difference between structural engineering and electronics, it was all just "engineering" to them, so I got all the "engineering" stuff. It was really challenging for a couple of years, I had to sit down and learn the basic concepts of a bunch of different fields, but then it was just soul sucking boring (plus I was working for filthy profiteering capitalist pigs). I lasted six years at that before the boredom got too much to bear. Made me really, really glad I got out of engineering before it was too late. That gave me leads to my current career, which is slightly technical, but not engineering. Basically counting things and doing really simple Excel stuff.
Posted : 08/10/2018 2:27 pm
...degree in political philosophy...
In that case (coupled with your meandering career history) I think I'll just disregard your opinions on pretty much all topics... TTFN.
Posted : 08/10/2018 2:31 pm
Page 3 / 5
