steel????
[Closed] steel????
[#566119]
I think I'm missing something here bought a cotic soul and not getting that spring feel like everybody is talking about ....I have bought a carbon post too ! I have been told that my seatpost maybe to high as I keep getting kicked in the air over everybump !!!!! please help
Rich
Posted : 19/05/2009 10:10 pm
Troll?
the spring in steel is talked up and is only mildly noticeable.
its still a hard tail not a soft tail
Troll
Posted : 19/05/2009 10:14 pm
Remove the top part of the seat stays and fit an elastomer, that will let the back end flex a bit more
Posted : 19/05/2009 10:27 pm
Let some air out of your tyres and hover a bit more off the saddle, anticipating the trail. Learning to ride properly again can take a while - stick with it. If you'd like to be patronised further, post on.
Posted : 19/05/2009 10:31 pm
ok cheers guys for help will do some chnges here and there ...might let the rear tyre down a bit think I have about 40psi in there at the moment
Posted : 19/05/2009 10:41 pm
Try 30.
Posted : 19/05/2009 10:59 pm
Try 38 first and tehn drop in 2 psi increments. If you go down as low as 30 on a hardtail, you're just gonna pinch flat it.
Posted : 19/05/2009 11:12 pm
 Bez
[i]If you go down as low as 30 on a hardtail, you're just gonna pinch flat it.[/i]
LOL
I'm sub-20 on one of mine.
Posted : 19/05/2009 11:40 pm
pinch flat if you ride badly. i run about 25/30psi, ride up and down flights of steps, 3/4ft drops and have pinch-flatted once in about 12 months. and that was trying to ride over a 2ft high bench.
probably tempted fate now....
and yes, lower the post a bit. drop it by an inch or so. you won't notice it too much on the ups and it allows for a bit more movement on techy bits.
Posted : 19/05/2009 11:47 pm
 JxL
I suppose it also has to do with the type of tyres you are running... With some thin side-wall tyres its probably much easier to pinch than some beefy DH ones.
Posted : 19/05/2009 11:55 pm
 Bez
Yup. Wider rims tend to pinch less too IME. And the fatter the tyre the lower the pressure you can use for the same vertical compression of the carcass.
Posted : 20/05/2009 12:05 am
yeah, that runs true. running 2.4 maxxis advantage on sunringle singletrack rims.
although my other bike,sanderson breath (cro-mo), is much springier than my mates Zaskar (alu) with a similar set-up. a much nicer ride and better looking frame to boot.
Posted : 20/05/2009 12:16 am
Yeah, 2.1 Nevegals on 717s
Posted : 21/05/2009 7:23 pm
2.0 michlin XCR, 20 psi, 717's, the peaks, only 2 pinch flats in 2 years 🙂
What are you comparing it to, a full susser?
Posted : 21/05/2009 8:50 pm
