Just bought a bike with one on, nearly new and seat drop 5mm when pushed down, as it does it lever push out a little.
I have fully serviced normal reverbs in the past and have had this issue and had to re set the IFP oil height when it happened, which stops the issue. But i know the Stealth internals are set up different.
Tried bleeding the lever, no different.
Will a full hose bleed stop it or is it the IFP oil height?
Probably air in the internal oil as you say, that's the symptom I had with my (admittedly normal way round) post. I'm pretty sure the stealth is the same internals but the other way up, that's all.
Let me know, I'm going to have to do a stealth at some point
I've got the same thing on my stealth. I've done a full bleed and it's the same...about 5mm up/down play when fully extended. Not noticed that the lever moves with it though. I'm loathed to pull everything apart, loosen off all the cable guides etc. to do another full bleed but guessing that's probably the best suggestion there is.
