Stanton Slackline -...
[Closed] Stanton Slackline - Optimum Fork Length
[#6061195]
...building, or trying to build one of these up at the moment.
Fork choice is a bit limited as it is an original 853 version with 1-1/8th steerer.
I like the idea of fork travel adjust, however I know I will probably never bother with it once the novelty wears off so I am now thinking more along the lines of a fixed fork for all round use. Are there any owners here who can offer any advice on optimum fork length? I'm 6ft 2... no idea if this makes a difference.
Stanton advise a Fox 32 Talas 150-120.... I see these take quite a bashing on the forums, and they are hellishly expensive. Fixed travel however would mean Revelations are also an option. I can't find travel adjust Revelations with 1 1/8th steerer anywhere.
Thanks for any help.
Posted : 24/03/2014 3:54 pm
 sv
Think there are dual position Revs available, I have fixed solo air 150mm Revs on my Slackline.
Posted : 24/03/2014 3:59 pm
I used to have a Revelation (426, I think) with a U-Turn damper, that was 110-140mm adjustable with a 1 1/8th steerer, so they do exist. I got mine second hand though, and sold it to a mate a couple of years back.
Posted : 24/03/2014 4:01 pm
SV - how did the 150s handle? Climbing any issue?
Posted : 24/03/2014 4:03 pm
I'm running 150mm Z1 Anniversary forks on mine.
It feels better with them on it than I did with the 130mm Z1's tget replaced. It's not the best at climbing though but I don't know how much if that is down to it being a tad small. Bloody good fun though.
I dont like the Talas forks myself as I find them sticky. I do like fox coil forks. According to the doom mongers there should be loads of 1 1/8th forks for 26 inch wheels kicking about.
Posted : 24/03/2014 4:07 pm
Just to throw some doubt in the mix I'm running mine with 160mm pikes, I'm 6ft 4 and .......... I love it !!!!
Jumping, singletrack, downhill it's great so much fun. As for uphill it's no rocket sledge but as long as you have a nice grinding gear it will get up.
[url= https://farm4.staticflickr.com/3674/13382824033_a90308f66e.jp g" target="_blank">https://farm4.staticflickr.com/3674/13382824033_a90308f66e.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/60261162@N03/13382824033/ ]image[/url] by [url= https://www.flickr.com/people/60261162@N03/ ]tomglass20[/url], on Flickr
Posted : 24/03/2014 4:45 pm
I'm persevering with TALAS forks (which actually seem fine to me) as my set of 36's give me 160-130-100 which covers all bases. It's in 130 the most but is a hoot at 160 too. I even put it down to 100 for the local BMX track.
Posted : 24/03/2014 4:54 pm
 Del
[url= http://www.chainreactioncycles.com/rockshox-sektor-gold-rl-dual-position-coil-15mm-2014/rp-prod109678 ]i think these are hard to beat for the money[/url]
Posted : 24/03/2014 5:15 pm
Ti slackline owner here, for the best part of a year I've had my 36 floats spaced down to 140mm, last week I decided to try them at 160mm, to my surprise I really really like it, slacker, more stable, still masses of fun and to my surprise was perfectly fine climbing too.
Posted : 24/03/2014 5:59 pm
Thanks for the input everybody.
I have found a set of fixed 150mm Revelations at JEJames with 1/8th steerer - these are looking tempting. Is it correct that Revelations can be spaced down internally if it turns out I am not getting on with 150mm travel for uphills?
Posted : 25/03/2014 1:07 am
...and one more query, is a 60mm stem too long for such a machine?
Can't wait till Thomson bring out the 27.2 dropper post..... expected May I believe.
Posted : 25/03/2014 1:09 am
What size frame are you guys around / over 6ft using? I'm tempted by one of these but not sure if at 5,11 im annoyingly between sizes.
Posted : 25/03/2014 2:19 am
Anyone run theirs with a 120mm most of the time?
Posted : 25/03/2014 6:33 am
 sv
Revs 2013 (and newer) need more than spacers IIRC.
Posted : 25/03/2014 1:09 pm
