Stans ZTR Rims
[Closed] Stans ZTR Rims
[#707333]
Can you really run them tubeless using only one layer of the yellow rim tape? I just cant see how it can be strong enough to not burst at the spokes holes..
Posted : 14/07/2009 2:24 pm
Yes - but you need the yellow strip rather than the sticky yellow rim tape
Posted : 14/07/2009 2:28 pm
Yes. The tape I used was yellow and sticky but. Clear stuff from B&Q works too - but you have to cut it to width
Posted : 14/07/2009 2:31 pm
Ive just used this
http://www.wiggle.co.uk/p/cycle/7/No_Tubes_Stan%27s_Rim_Tape/5360042194/
the 21mm version.
Posted : 14/07/2009 2:32 pm
yes - the tape is well strong and does not stretch
Posted : 14/07/2009 2:52 pm
Alright, cheers.
Posted : 14/07/2009 3:05 pm
It does make inflating tyres harder than with rim strips though, they're baggier on the rims.
Posted : 14/07/2009 3:06 pm
True, but once they're up, as long as the tyre bead is reasonably rubbery and smooth, the bead socket on Stan's rims seems to hold them nicely.
Posted : 14/07/2009 3:15 pm
