After returning from the Alps I have approx 20 damp sealant spots and visible cuts on my rear tyre.
Is this likely going to go flat at any time now if I continue to use it, or once it's sealed it will remain sealed?
Posted : 24/07/2016 3:58 pm
Should be fine. Might be worth shaking it to see how much liquid sealant is in there and consider topping it up.
Posted : 24/07/2016 5:52 pm
Mine has managed to seal two 5mm rips in the sidewall. More jizz injected using a cow syringe and it's still doing fine.
Posted : 24/07/2016 8:06 pm
As I've mentioned in another tubeless thread, stan's sealant seems to seal the hole's other sealants struggle to reach!
Posted : 24/07/2016 9:26 pm
Nutrak sealant is, as far as I can tell, piss poor.
Posted : 24/07/2016 9:27 pm
