Just about to order some crest650b rims, but unsure as to weather the rim tape is the 21mm or the 25mm. Just want to make 100% sure before I order, does anyone know?
25mm
Sweet, cheers. I think that the Stans website could do with a re-jig, it's not 100% clear. Thanks boffins.
You can use either width tape (21 or 25mm) on Crest rims - if you use 25mm you will need to trim away the excess with a craft knife.
http://www.notubes.com/Crest-Rims-C54.aspx
The cheapest way to get the tape is to buy the Hope tubeless kit which has a roll of 25mm Stans yellow tape, 2 Univeral valves and a couple of small bottles of sealant.
£18 delivered from here -
http://www.pedalon.co.uk/acatalog/hope-crest-and-flow-tubless-rim-kit.html
