stans rim and valve...
[Closed] stans rim and valve problem
[#1921179]
I have a new set of hope hoops with stans crest rims. I pumped the tyre up today and the tubeless valve has pulled through the inner part of the rim.
It wont push back through and I dont want to force it through the rim outer unless absolutely necessary. Anyone else had this and managed to remove the valve without damaging the rim?
Also I am not sure if the valve was too small or the hole in the rim too large?
Posted : 22/08/2010 9:23 pm
have you got the correct valve? Think it should be Stan's No Tubes Olympic valves you would need.
Posted : 22/08/2010 9:35 pm
yep, definitely correct valves. Also had the same type on olympic rims with no problems
Posted : 22/08/2010 10:45 pm
don't suppose they're drilled for a schraeder ?
Posted : 22/08/2010 10:50 pm
This happened on the trail last week while I was pumping the tyre up. I ended up using a rock and hit the valve head until it popped back out.
Installed a new valve the other day, and the rim's fine.
Posted : 22/08/2010 10:54 pm
