I notice that they dont have eyelets. Are they more prone to cracking over time round the spoke nipple without eyelets? I want to run 2.3's tubeless tyres. Will the Arch's be ok with 2.3's? or should I just stick with Flow's?
[i]Are they more prone to cracking over time round the spoke nipple without eyelets? [/i]
Not that I've heard of, no.
[i]Will the Arch's be ok with 2.3's?[/i]
Yes. I run 2.35in High rollers on my 355s. However, what sort of riding are you doing and are you....hmmm...big boned?
just average 5'10 85ish kg
[i]just average 5'10 85ish kg [/i]
Should be fine on Arch. Worth pointing out though that if you get a set of Hope Hoops with either 355s or Flow you'll save money over getting a custom build which is the route you'll have to go if you decide on Arch
