Or will getting forks for it in the future be a problem?
Full sus 29er BTW
I reckon you'll be fine with 1 1/8.
The 1.5" or tapered steerer 'standards' don't appear to have taken the world by storm.
I don't see 1 1/8 disappearing any time soon.
+1
Thanks both
My next bike will 100% not be governed by the head tube size.
Don't worry, there'll be another few 'standards' out before 1 & 1/8 become obsolete...
DaveyBoyWonder - MemberMy next bike will 100% not be governed by the head tube size.
Unicycle?
Hmmm, I'm not so sure. I've now got two sets of tapered forks sat in boxes in the garage without frames to put them in. If you can, I'd look for 44mm where possible. That way you can put whatever fork you want in it
There will be demand for 1 1/8" forks for a long time yet, despite the best efforts of the marketing space cadets.
+1 for 1.5" headtubes. All bases covered.
possibly tapered and definately 1.5 forks do seem to be a bit cheaper, especially s/h as they fit less frames
Whats all this xx44 headtube sizes? what size steer do they take?
44mm headtube is the way forward.
Just heard that the Cotic Solaris with have a 44mm headtube, the new Salsa marachchhhejnfbbf 2 ?? has a 44mm headtube to name but a few.
Why 44mm... will take both 1,1/8 and tapered fork.
They 'will' be the industry standard in time. 🙄
will it also tke 1.5 steerer forks then?
1.5" = 38.1mm so I reckon it would.
+1 for the 44 standard. whilst it wasn't something i particularly looked for when i bought the mega (already had 1.125 fork) it's got all bases covered. as someone said - lots of good deals on tapered/1.5 tubed forks around.
Not sure....with a tapered set up you need a 44mm external cup at the bottom and the standard inset one at the top. Im 'guessing' that as the bottom can work with an 44mm external cup then effectively the same type of cup can be used on the top.
Check
This being STW...someone will come along and confirm or correct me with some abusive ranting ! lol 🙄
XX44 is indeed what you're best off with on a 29er or any bike with a long fork, ie 500mm or more. Why limit your options? Imo only.
Considering that so many people with 1.5 or tapered headsets end up putting proper forks in them, don't worry about it.
