Standard release or...
[Closed] Standard release or multi-direction release for first time clipless?
[#1187223]
Hi all
Just got my first set of clipless pedals, the Shimano M647s. Bit dubious about not unclipping in time when I need to.
Is it best to use the standard release cleats or go for the multi-direction release cleats to start with?
Thanks
Posted : 05/01/2010 8:04 pm
multi initially IMO.
Posted : 05/01/2010 8:24 pm
Standard, you'll soon get the idea (once you've had a couple of falls) 🙂
Posted : 05/01/2010 8:29 pm
I'm just starting out on clipless and have gone for the standard. its not as hard as I'd imagined, although the icey roads arn't helping!! 4 offs in about 100m at the weekend.
Posted : 05/01/2010 8:31 pm
Maybe stick to flats until the ice has dissipated! Standard are fine as long as you slacken off the tension. Mind, I don't really get SPD's for off road TBH.
Posted : 05/01/2010 8:35 pm
multirelease have the nasty habit of pulling out at inopportune moments, I hate them, and have only used them when I bought them by accident... Just get standard release and get on with it. Much better. FWIW I didn't fall off when I started using them, although I've seen many others do so.
Posted : 05/01/2010 8:38 pm
