Stanchion wear
[Closed] Stanchion wear
[#3088234]
how much stanchion wear is too much? just changed the wiper seals on my fox floats and it is a mess on the damper side under the seals. i have done the wiper seal service a few times but only while the legs are still attached. other than more friction the structure is sound.
Posted : 26/08/2011 8:31 pm
Run them into the ground is usually the best advice when they've gone
They last a surprisingly long time
Posted : 26/08/2011 8:33 pm
 grum
Nail varnish trick works too.
Posted : 26/08/2011 8:39 pm
uplink that was my idea too 😀
Posted : 26/08/2011 8:42 pm
[b]i have done the wiper seal service a few times but only while the legs are still attached. other than more friction the structure is sound. [/b]
so you have never done the Fox Factory recommended "lowers service" which takes only 10-15 minutes with practise?
there is a reason that Fox (and most competent suspension tuners or suspension-trained mechanics) recommend the complete "lowers service"
doing the 'wiper seal service' is a quick-fix, but causes problems with premature stanchion wear in the long-term 😉
Posted : 26/08/2011 8:44 pm
There are quite a few videos and write ups of it being done without removing the lowers. Never thought there could be so much unseen damage, Lesson learned.
Posted : 26/08/2011 9:38 pm
 flow
Dime bar!
Posted : 26/08/2011 9:42 pm
Wouldn't say "dime bar" just followed a guide online as i never had any instructions with the bike.
Posted : 26/08/2011 9:55 pm
