I know there's a few other ST4 owners on here and wondered if there's any advice or documentation on how to remove/service and replace the rear triangle/bearings? There's nothing I can find on the Orange website for the ST4, it's all 5's or patriot documentation
Whilst getting better at maintenance jobs I've never attempted this on a full sus so any help would be great
Any thoughts from the saturday browsers?
It is easy to dissasemble the rear triangle - just unbolt anything you can. I found that a 'just small enough to fit' drift (a socket) and a whack from a hammer, with frame supported over a gap just big enough for bearing worked fine. Replacing is the reverse.
You can also get proper bearing pulling tools if you are concerned.
This may help
[url]
Thanks for that both
