As title 2012 frame
Anyone know?
anyone?
190mm eye to eye, I'm fairly sure the stroke was 50mm
[url= http://www.orangebikes.co.uk/bikes/2012/st4_pro/ ]2012 ST4[/url]
Why you ask... Just curious that's all?
Coss I might change the standard fox evelution rl that came on the frame when bought
I knew it was 190mm it is the stroke length? I thought it was 50mm but when measuring the shock it's more like 55mm but not quite 57mm which is the next size up from a 50mm that's why i'am asking question as I'm a little confused
Can any one help in stroke length ??
190x50 shocks have a wee bit more exposed shaft than you'd expect, quite normal.
Is this true what northwind says
Anyone else
Yes 190x50...definitely...positively...most certainly it is 190x50....
190mm eye to eye shocks don't come in a longer stroke than 50mm...some spesh and rocky mountain frames take a 190x44,..but not on an Orange, they take a 190x50.....
Edit...Northwind is correct as well....
Cheers khani
