SS ratios ?
[Closed] SS ratios ?
[#224949]
Need some help with my new tricross single speed....
first one - when i get a puncture and have to take the rear wheel off.....
How do i get the tension right when i put it back on ? Also can i use a normal QR skewer or even a halo hex - i don't want to carry round two spanners !
Secondly, what ratio do you recommend for a beginner ? The tricross comes with 42 at the front and 18 at the back...
I ain't going to get up a lot of the hills around here...
thanks 🙂
Posted : 18/01/2009 7:35 pm
 dobo
depends on how you intend to use the bike? off road, commuting, road etc
i didnt help much did i 😉
Posted : 18/01/2009 7:38 pm
1 ring spanner is enough
Pull wheel back and nip up gently - QR won't hold securely
Try a 39t - Surly do a suitable one
TTFU 🙂
Posted : 18/01/2009 7:41 pm
good point though
well..
commuting and general rides when I just grab the easiest thing out the garage....
I suppose its the choice between getting up hills and spinning madly on descents ?
Posted : 18/01/2009 7:42 pm
I can get up most stuff on the 39 - and 19-20mph on the flat before you spin out....
Posted : 18/01/2009 7:44 pm
hi rob - nice to hear from you
was going to mail you but cant find your email address in the profile ?
Posted : 18/01/2009 7:45 pm
Have you got a chain tug fitted? I find these helpful in getting the chain line straight and tensioned when you repair a puncture. Still need a spanner for the bolt though. The stock wheels on the tricross are poor, so a slightly misaligned chain can accelerate wear and tear on the hub - mine only lasted a few 100 miles.
It's not possible to choose a ratio for a SS CX bike that will do everything - the difference in ratio necessary for proper trail work and beasting along down the tarmac is massive. It's a bit different from a SS MTB in that sense. The stock 42x18 is a good start - this would be on the light side of things IME, you wouldn't want to go much easier than this if you're riding mainly on roads.
Posted : 18/01/2009 7:50 pm
I run a 32-18 and i can still pedal at 16-18mph on the flat and i am by no measure that last to the bottom of a fell/hill.
Posted : 18/01/2009 10:57 pm
im on 52:18 but its only used on tarmac, and keeping up with traffic is more important than anything else.
the hills took a while to get used to.
Posted : 18/01/2009 11:43 pm
