SS mtb choices?
[Closed] SS mtb choices?
 aw
[#286385]
Right near the time to decide on a new SS MTB. I have it down to a few but first my requirements...
Ti or steel
fully rigid or just front fork
26 inch wheel about 18 inch frame
price below £1000
test ride required preferably in the south
needs to look good or cool 🙂
My shortlist...
1. Cotic simple or soda (SS?)
2. Kona explosif convert
3. ti 456 SS
4. Scandal (I know I said steel)
5. Genesis
6. on-one inbred
any other you can recommend?
I would like some comments if you own or have had these bikes especially if you can compare them with others 🙂
Needs to be a marked improvement on my existing kona cindercone 97 SS conversion pictured below...
Posted : 08/02/2009 4:58 pm
 Jase
I had a non disc mount version of the Inbred and it was fantastic.
Replaced it with a Voodoo Wanga which felt almost as good.
Now just building up a SImple.
All fully rigid BTW.
Posted : 08/02/2009 5:01 pm
 Jase
Oh and a friend had the Scandal and he said the ride was so hard compared to steel.
Posted : 08/02/2009 5:03 pm
 aw
yes scandal maybe hard but the carbon rigid forks help I believe?
what is the simple like Jase?
inbred sounds good but would it not be any better than the cone?
The lack of discs would not be a problem as in most situations v brakes are fine!
Posted : 08/02/2009 5:06 pm
 Jase
Not sure on the Simple yet as haven't fitted the chain yet.
A lot lighter than the Voodoo and Inbred though.
Posted : 08/02/2009 5:09 pm
 aw
I guess the uphills will be about weight...I love single track so I want a bike to do that job at least
Posted : 08/02/2009 7:37 pm
 aw
bump
Posted : 08/02/2009 8:25 pm
I had a Singular Swift that was a great bit of kit, climbed as well as any bike ive ever had, just singlespeed never really suited me, took me over half an hour on road to get offroad, if you get me, great on singletrack. Well worth a look. Very light and beautiful too.
Posted : 08/02/2009 8:34 pm
 aw
is that a 26" or 29" wheel swiftacular?
I love the look of the singulars I must admit...if |I wanted to test where would be the nearest place?
Posted : 08/02/2009 8:37 pm
The Inbred has that solid do everything feel. The Cotic and Genesis have more Zing for XC which I prefer, and is similar to the old steel Kona feel.
The others I haven't owned so can't compare.
Posted : 08/02/2009 8:49 pm
aw - Looks like you need to sort out the chain tension on youe Kona
Posted : 08/02/2009 9:00 pm
Whyte 19, awsome bike
This one is for sale £950 you can gave a test ride im in bristol the brakes have been swopped to mono mini and thr=e tryes and sadle have been swopped by its all good kit.
Very positive feel to the stearing goes where you point it fast light ans comfortable ride.
Posted : 08/02/2009 9:01 pm
 aw
the cotic might have more zing like the old konas but are they more superior otherwise I might as well stick with my old kona!
Posted : 08/02/2009 9:02 pm
Love my simple
Posted : 08/02/2009 9:27 pm
I've tried several now and my favorite is my 853 inbred - takes up to a 5" travel fork, the sliding dropouts work perfectly and it handles perfectly, for me at least.
Posted : 08/02/2009 9:33 pm
853 Inbred for me too. Previously had a Voodoo Wanga, but much prefer my OnOne.
Posted : 08/02/2009 9:39 pm
Clubber, what are those forks and where did you get them from, I want to run rigid on my OnOne, but am not having much luck finding suitable ones?
Thanks,
Stu
Posted : 08/02/2009 9:43 pm
My Explosif. Not for sale, but might help you make your mind up.
Kona Explosif Singlespeed
Got two sprockets on the back as I've lost a spacer, and there is enough fore-aft adjustment to change from 32:16 to 32:18 without messing with the chain which is nice 🙂
Posted : 08/02/2009 9:54 pm
 taka
all them bikes would look good i they had thease things called GEARS
Posted : 08/02/2009 10:15 pm
stu - the rigids on mine are pipedream ones. I'm not sure if they still do them though. Any 440ish fork should be fine though.
Posted : 08/02/2009 10:21 pm
Cheers Clubber. I'm being fussy and want a specific shape - like yours! I'll check out PD.
Thanks,
Stu
Posted : 08/02/2009 10:24 pm
I have a genesis i0 i find it awsome and british made. 2009 is better specked than the 08 which i have i upgraded brakes and wheel but you wont have to if you got 09. also customer service is great with them. (and it was lighter than my friends Inbred single speed)
Posted : 08/02/2009 10:53 pm
stu, i could be tempted to part with them (i'd like some carbon ones). Drop me an email if you're interested (address in my profile)
Posted : 08/02/2009 10:57 pm
tala, if they had gears, then they wouldn't be singlespeeds now, would they? (pats him on the head and sends him back to play with his dolls in the corner). FWIW, I have an 853 Inbred with On-One carbon forks and it is very light, and an absolute delight to ride, although my experience with SSs' is restricted to a Handjob with Planet X rigid forks and a Surley tensioner. The 853 would be the bike I kept if I had to get rid of three of my four.
Posted : 09/02/2009 12:31 am
"all them bikes would look good i they had thease things called GEARS"
They do, they just happen to have just the one (with the exception of the explosive, with 2)
Somehow I don't think you've ever ridden(/been beaten uphill all the time) with/by a SSer
Posted : 09/02/2009 3:43 am
You could do wonderful things to your existing bike for a grand! Think Paragon sliders to start with 🙂
Posted : 09/02/2009 9:12 am
[i]is that a 26" or 29" wheel swiftacular?[/i]
Are you on crack? Look at it!! The photo looks like it's been stretched.
Posted : 09/02/2009 9:48 am
The genesis IO looks good.
frame only is also available for £200.
Posted : 09/02/2009 10:23 am
Yeah I second freeandsingle's comment. If you like the feel of the Kona you'll struggle to improve much on that. I have a Unit which is a superb frame.
How about an EBB and a disc-mount for your Cindercone? Should be around £300 from Argos including a full paint job. I'd keep it rigid if I were you - but if it runs 1,1/8" aheadset there's plenty of scope to try both types of front end.
Keep it sustainable 😉
Posted : 09/02/2009 10:32 am
 aw
paragon sliders?
wheel upgrade recommendation?
Posted : 09/02/2009 11:15 pm
 aw
bump
Posted : 11/03/2009 1:24 am
I just SS an old bike frame lying around for peanuts :O)
But I like the Gensis Xo frame.
Kona has been done to death.
Titanium? that would be nice!
I'd have the Cotic.
Posted : 11/03/2009 1:30 am
Started with one of these - [IMG] [/IMG]
Then got one of these - [IMG] [/IMG]
Now have one of these - and the best so far.... [IMG] [/IMG]
Posted : 11/03/2009 10:28 am
Five Bar what are those? no phots ...... My gash, put together for £250 On One Inbred EBB is my most fun and used bike and I have a bit of a choice. Most of those above and may be the Love Hate as well - so down to personal pref, good luck R
Posted : 11/03/2009 10:34 am
 jfeb
If you want to test ride a Singular you need to contact "Sam" on this forum and he will try to set you up with one.
Posted : 11/03/2009 10:41 am
I've had the Inbred and Kona singlespeeds, now on a Nicolai. If I was buying again and forgeting Nicolai it would be between Cotic and Sanderson. However if the Scandal singlespeed does happen then that for certain.
Posted : 11/03/2009 10:54 am
Whats the Nicolai model ? how does it ride ?
Posted : 11/03/2009 11:07 am
Ozzybmx
It's an Argon. It's a great ride (for me anyway) one of those bikes that your other bikes can't live with and have to go. Modified since this, my only picture with MonoMinis, Eggbeaters and USE bars.
The sliding dropouts are great and it means I can run a very SWB. Also I've moved away from rigid forks. Lightweight suspension with lockout is more versatile.
[img] http://www.woburncrankers.com/Photo.aspx?iPhotoID=518 [/img]
Posted : 11/03/2009 11:18 am
Nice mate !!! i have an Helius AM on the way , and already thinking about the next bike 😀
Posted : 11/03/2009 11:21 am
singular hummingbird...26/69er..
www.singularcycles.com
Posted : 11/03/2009 11:34 am
I initially converted a Merlin Malt 1 to SS, then used a Malt 4 frame for the purposes with a tensioner. Fun, but I personally found the top tube relatively short and the bike twitchy, particularly with the need to be out of the saddle quite often.
In the end I bit the bullet and bought an Inbred (steel, sliding dropout) and absolutely loved it. The added top tube length made standing up a lot easier, the bike felt less twitchy and more surefooted too. The springiness of the steel frame (and not just an On One) makes for a lovely ride without the jarring buzz of some aluminium frames. However, it is quite a heavy frame in the first place.
I've just bought a slot dropout Scandal, because the geometry is the same but it is lighter. Only ridden twice so far, but it's definitely lighter and sharper, and therefore feels faster, BUT, it is a lot stiffer. There is still some give, and it's not uncomfortable, but it doesn't have the springiness of the old Inbred. For me it was a wise move, I want something I can do more events on and I'm willing to take the 'comfort' penalty to do that.
At the end of the day, the ideal thing would be a Ti one, but they haven't made those in years, and I'm not sure they will be making any soon either.
Posted : 11/03/2009 6:13 pm
