SS: chainring bolt ...
[Closed] SS: chainring bolt unscrewing oddness
[#3071224]
Cleaning the ss for the first time [s]ever[/s] in a long while tonight, noticed that all of the chainring bolts were somewhat loose. And when I say loose I mean *insert double entendre of your choice, so long as it describes a very loose thing.*
What's the most likely culprit, do you think?
Initial thoughts were one or more of the following:
a) Hamfisted spannering resulted in undertightened bolts when first built
b) No threadlock
c) Chainline issue-induced 'waggling' has undone them
d) Thermal expansion/contraction during winter
e) Other
I've never had them come undone on any other bikes before, even ones I've dis/assembled myself.
Glad I cleaned/noticed it this weekend or it would have likely ended badly for both bike and rider. Eek.
Posted : 21/08/2011 10:35 pm
are they short enough to not bottom out? ie single speed specific?
tbh you probably just need to do them up tighter. The proper tool does help and is only £3.
Posted : 21/08/2011 10:38 pm
a) Hamfistedness
[u]dont[/u] use threadlock!!
Posted : 22/08/2011 12:32 am
I've only had a chainring come loose once in many thousands of km on singlespeed or Rohloff.
Best bet is do them up tight, ride for a bit to let everything settle in, then tighten them again.
I also avoid aluminium bolts as I don't feel I can tighten them enough without them breaking.
Posted : 22/08/2011 7:54 am
Use threadlock 222 as is only low strength and will only require 5Nm to get loose. I use it on all bolts.
Posted : 22/08/2011 8:28 am
Thanks all.
Short/ss chainring bolts used, no threadlock, and I used the proper tool - just not well enough, by the looks of it.
Having tightened them up and had a good old look on the commute this morning it seems that the chainline isn't quite right - separate issue, but good to notice...
Posted : 22/08/2011 12:34 pm
Happened to me a couple of times before in the past plus its sounds like my cleaning regime too, worst time was when out a fair way from home when the bolt fell out which then caused a surly stainless ring to basically fold in half under load resulting in a long scoot home, subsequently always carry a spare bolt and peg spanner for the back with me now and also check reasonably often too now.
Posted : 22/08/2011 12:56 pm
