SS 29er ratio???
[Closed] SS 29er ratio???
[#4446377]
i just bought my first mtb (a very nice singular swift 29er). looks so good, but im already keen to convert it to a SS
its got a surly 36t chainring up front that i dont want to change. On other posts ive read 2:1 is a good gear ratio, so that would mean an 18t on the back. but is this the same for a 29er??
so my question is how many teeth should i run if i have a 36t chainring?
cheers
Posted : 10/10/2012 7:48 pm
Posted : 10/10/2012 7:50 pm
32:18 is 29er ~32:16 equivalent. 36:20 is about the same as that.
Posted : 10/10/2012 7:54 pm
Depends on how fit you are, where you ride etc. 36:18 will be a good starting point, then fine tune if you find it too hard/easy. I started on 32:16 on my Swift before, eventually, settling at 34:18 as my 'sweet spot'
Posted : 10/10/2012 7:56 pm
32:16 34:17 36:18
are they all the same??
also, so on a 29er im looking at 36:20 to start??
Posted : 10/10/2012 8:49 pm
Mine's 32 X 18 ss, 32 X 16 fixed, nice............
Posted : 10/10/2012 8:51 pm
OP, the answer was in the thread you started on SS ratios the other day )
Posted : 10/10/2012 9:00 pm
32:19 here in the NW Alps
Posted : 10/10/2012 9:02 pm
OK; a 2:1 ratio (eg. 32:16) is the starting point for a 26er. Because a 29er has a bigger wheel, each pedal turn will take you further for the same gear ratio, making the gear proportionally higher overall by 29/26 (because circumference is proportional to diam - with me so far)
Hence instead of 2:1, you want something slightly less as a starting point for a 29er.
32:16 x 26 = 52
32:18 x 29 = 51.6
or for you with a 36T front:
36:20 x 29 = 52.2
Now, if you want something slightly easier, because you live in a hilly area, or are a spinnier rider, then up the rear or reduce the front accordingly (not sure how easily available 21 or 22T rears are though). I doubt you want much harder unless you live somewhere properly flat like Thetford.
FWIW i run 34:18 x 29 = 54.7 but I have got a wonky ring on the front which is a whole different question
http://singletrackworld.com/forum/topic/elliptical-single-speed-chainrings
Posted : 10/10/2012 9:27 pm
he doesn't make it easy does he
(I just did my maiden 29er SS ride, on 32:18, and I'm sure I found it a tad spinny compared to 32:16 on my SS, so may up the back to 17).
Posted : 10/10/2012 11:10 pm
