SRAM XD/XDR bobbins
[Closed] SRAM XD/XDR bobbins
[#10836852]
I've have some new to me Niner wheels which came with Shimano and XD freehubs - I specifically want to run a SRAM cassette. The XD one appears unused, and now I can see why. Although it says XD only on it, I can't get my SRAM cassette to engage with the splines in order to tighten up and the driver has a shoulder on the outer face which looks very like pics of XDR drivers. The cassette fits fine on another XD driver - which doesn't have the outer shoulder.
I can buy another cassette but the web seems to suggest I need a 1.85mm spacer behind it to fit. I can't see how that will work because I can't get the cassette far enough onto the driver to engage the splines in the first place.
Anyone any experience of this problem - and which 10-42 cassette I need that will fit?
Posted : 28/09/2019 1:14 pm
I’m sure XDRis supposed to be identical to XD, just with that slightly longer splined section. Do you have a picture?
Posted : 28/09/2019 7:20 pm
I'll sort one out. I've been looking at other pics of XD and I think that's what it is, but it's definitely a different shape to my other XD driver - and seems to be about 1.85mm longer... Pics on the web seem to vary too. Think I might stick with Shimano!
Posted : 28/09/2019 7:30 pm
XDR should be exactly the same as XD, but slightly wider to allow 12spd road cassettes, which are wider than MTB 12 speed cassettes, which then require a spacer on XDR.
Posted : 28/09/2019 8:48 pm
Posted : 29/09/2019 10:32 pm
Yeah, looked at that. Doesn’t really help me though. Think I just need to try again and look at the way the splines engage. I hadn’t realised it was like Shimano, with a narrow spline at one position.
Posted : 30/09/2019 9:08 am
I’ve recently put a sram xd Cassette on an xdr freehub using the 1.8m took a couple of mins to line up the splines correctly and didn’t really feel like it had engaged before I started tightening but actually went on fine.
Posted : 30/09/2019 9:19 am
I've just got some Onyx Vesper hubs. They come with the xdr freehub and a 1.85mm spacer. This spacer is held in place during shipping with an o-ring.
Seems some folks were struggling to fit cassettes because they hadn't noticed the o-ring or realised it was just there to hold the spacer.
Check there isn't something on the freehub that doesn't need to be there.
Posted : 30/09/2019 9:35 am
