sram x5 woes
[Closed] sram x5 woes
[#6748299]
Hello.
I have a banshee x 2012 which came with the an x5 gearset.
When it gets cold i cant find the strengh to change gear on the front mech using my left hand.
It gettings very stiff.
I read online that its a common issue with the x5.
Do i need to replace the shifter and mech?
Also another issue with the rear mech is that it changes gear on its own lol. I have tried tweaking as much as i can but on some of the middle gears it just wont settle?
Please help!
Christian
Posted : 04/01/2015 6:18 pm
Ever changed the cable since the bike was new?
SRAM front mechs are a bit stiffer generally though. New cable and outer makes a remarkable difference. Remember you'll need 1.1mm cable rather than the usual 1.2mm.
Changing gear "on its own" could be spring in the mech, stiff/rusty cable, needing a re index, shit in your cassette, or even a bent mech hanger.
I have a x5 and x7 setup, both seem fine.
Posted : 04/01/2015 9:26 pm
Change your front mech to Shimano XT and the problem will go away. The shifters are pretty decent.
Posted : 04/01/2015 9:43 pm
The X5/X7 on my 2013 Spearfish has never shifted as well as the X5 does on my 2014 Fatty. Loads less chainslap too.
Posted : 04/01/2015 10:06 pm
Can Shimano and SRAM be mixed?
Posted : 04/01/2015 11:17 pm
I think the actuation ratios are different, so you cant use a sram shifter with a shimano mech. I'd fix the low hanging fruit first before I changed the whole mech or shifter.
Posted : 04/01/2015 11:24 pm
Mixing is fine for the front shifter and mech.
Posted : 04/01/2015 11:35 pm
On another note i had been looking at different shifters and noticed some of the sram x9 and x0 have a indiator windows and some dont. Are these different year shifters and are the indicators worth having as i quite like the idea.
I understand its not going to help the stiffness but sometimes i find myself looking down to check what gear im in
Posted : 04/01/2015 11:45 pm
