I used to run:
XT 2x shifter
Sram X7 FM (direct mount)
XT 2x10 crankset
it worked perfectly.
I'm trying to switch the shifter to an X9 two speed. There appears to not be enough movement in the mech to shift up properly to the big ring. Cable tension is good and the stop screw is nowhere near being contacted.
Is this a compatibility issue? ie XT crankset requires Shimano shifter, and a SRAM shifter won't work? (Presumably because the chainrings are spaced differently?)
Ta.
Running XT Front with XO Twistie on a Truative/SRAM 2x Chainset so not that specific
yeah - AFAIK it should work, but I can't figure out why. All I did was switch the shifter really.
Suspicions are aroused because the mech body is nowhere near contacting the H stop screw, even with it wound in fully. The shifter's not pulling enough cable, basically.
Fixed: hidden inside the outer, the cable had a loose filament causing extra friction. Shifting works fine with a new cable. Thx for stopping me barking up the wrong tree.
- M
I run Sram shifters, Shimano Crankset and Sram mechs and have no issues at all.
That doesn't help.
