SRAM S1400 crank re...
[Closed] SRAM S1400 crank removal help
[#4915862]
I've always been a Shimano crankset person but have a frame here with an X7/S1400 chainset fitted which I want to remove.
It has an inner 8mm hex and an outer larger hex - do you use a square taper type crank puller or something? Looks like a trip to the bike shop in order. Advice much appreciated thanks
Posted : 28/02/2013 2:42 pm
The larger bit simply captures the 8mm bolt so undo that (the 8mm) and the crank will come off.
Posted : 28/02/2013 3:00 pm
So you need to remove the 12mm hex first or I undo the 8mm one and the other one comes with it?
Posted : 28/02/2013 3:09 pm
Sorted now thanks. I didn't realise it was self extracting.
Posted : 28/02/2013 3:47 pm
This is probably bad form, but if you want to sell the x7 cranks, I would be interested.
Cheers.
Posted : 28/02/2013 9:22 pm
Posted : 28/02/2013 9:23 pm
Lol what would you pay for them? They're brand new and never used - removed from a new bike frame.
They are Truvativ/Sram S1400 175mm 2x10 39/26
Posted : 01/03/2013 1:02 am
