Sram rsc lever rebu...
[Closed] Sram rsc lever rebuild
[#9544574]
Morning folks. got a problem with my RSC lever which, after much internet browsing, definately looks like the piston inside the lever assembly is sticking. i have read you need a special tool for the job and was thinking about purchasing the below kit. Has anyone attempted to repair there own and if so, how hard is this?
http://www.ebay.co.uk/itm/SRAM-Guide-RSC-Ultimate-Disc-Brake-Lever-Internals-Rebuild-Part-w-Tool-VER-G2-/222641435524?hash=item33d676b384:g:~u8AAOSwSRpZtk7e
Posted : 12/09/2017 7:41 am
Anyone?
Posted : 13/09/2017 8:01 am
Go to the SRAM tech manual site and download the Guide tech manual - just had a look and rebuild is clearly explained. So far I've found SRAM tech instructions excellent, with very clear step-thru guides.
Posted : 13/09/2017 11:55 am
SRAM replaced the lever on my RS when this happened via Evans after more than a yr. If you have receipt worth trying to put in as a warranty replacement. If you didn't buy new you can get the internals for a rebuild on eBay / doesn't look that hard to replace if you have a little time / patience.
Think this is what you need: https://m.ebay.co.uk/itm/Sram-Guide-RSC-Ultimate-Piston-Assembly-and-Return-Spring-Qty-1-/222568241236?
Posted : 13/09/2017 12:12 pm
As above, I also now recall there was an issue on early Guides suffering this issue (search mtbr.com), so try the warranty route if you can, but good luck on turnaround time/the parts being available.
Personally I'd just buy the kit including the tool and do it yourself.
Posted : 13/09/2017 1:07 pm
Thanks for replies folks. didn't buy new so no receipt unfortunately. I think i'll buy the kit and try and fix myself - just wasn't sure how hard/easy it was. i had loked at the instructions on the sram site.. looks a bit dawnting but i'll give it a go.
cheers
Posted : 14/09/2017 3:43 pm
